Hi Ajin.
Yes. As you already have an external dhcp server, there is no need to complicate your life. Just tag this vlan to the switch ports were your APs are connected and make sure that your dhcp server provide the working dns address, can be public dns server.
You need to create named vlan on access points so you can select it when creating ssid.
Original Message:
Sent: Feb 15, 2023 02:16 PM
Subject: Captive portal not showing when using different VLAN
Thank you Gorazd. So you just introduced a new vlan and assigned to the SSID? There is no IP assigned anywhere in the controller for this vlan? I'll try again.
Original Message:
Sent: Feb 15, 2023 03:48 AM
Hi Ajin.
Yes, I'm aware that you are using Central managed APs.
I just configured internal captive portal on Central and set it to nondefault vlan.
I tagged vlan 100 to AP port. Client was connected to the portal without a problem.
Interface setup on the switch is like:
interface 21
name "AP303-03-Lj"
poe-lldp-detect enabled
tagged vlan 100
untagged vlan 1
lldp top-change-notify
lldp enable-notification
exit
Gorazd Kikelj
MVP Expert 2023
Original Message:
Sent: Feb 15, 2023 01:40 AM
Hi Gorazd,
This is APs managed by Aruba central. And the guest access is working when the default vlan is set. Not working with new vlan which already has access to internet.
Original Message:
Sent: Feb 15, 2023 01:28 AM
Hi Ajin.
Check the pre-login role the client is getting. Does it have the correct vlan? For captive portal to work, it need to limit access to necessary services like dhcp and dns and redirect to the captive portal. After successful login a new role need to grant required access to the internet and other services.
Best, Gorazd
Gorazd Kikelj
MVP Expert 2023
Original Message:
Sent: Feb 15, 2023 12:59 AM
Yes, it has. We are using the internal captive portal and not the cloud guest feature.
Original Message:
Sent: Feb 14, 2023 04:50 PM
does this new VLAN also has full internet connectivity?
Original Message:
Sent: Feb 14, 2023 10:41 AM
Yes, the client is getting the IP from this new vlan when connected but not redirecting to captive portal for authentication. When we change to the native vlan and try connecting, it's connecting and redirecting to captive portal without any issues.
Original Message:
Sent: Feb 13, 2023 04:39 AM
so with your current setup, the clients get IP address on this other vlan right?
Original Message:
Sent: Feb 13, 2023 12:28 AM
The vlan is already tagged on the switch port. The vlan should have access to the controller virtual IP (different vlan) to get to the captive portal page?? I remember in physical controller, we have to assign IP address to the vlan interface for redirecting to captive portal, but in Aruba central I cannot see such option.
Original Message:
Sent: Feb 12, 2023 04:52 PM
you need to ensure that the other VLAN that you are selecting is allowed on on the switch port that connects to the AP.
The switch port should be configured for VLAN trunking 802.1Q
Original Message:
Sent: Feb 12, 2023 02:24 AM
I have APs managed by Aruba Central. I want to configure captive portal for guests and it is working when I am using the default vlan. But I want to use a different vlan for guest and when I put that vlan, the captive portal page is not coming. How can I solve it?
