Captive Portal Page Configuration Issue
  • 1.  Captive Portal Page Configuration Issue
    Posted 21 days ago
    Hi Everyone.  I am experiencing an issue with displaying the contents of the captive portal landing page, which I have set for my Guest SSID.  Prior to migrating over to Aruba Central, and page was configured using an on-prem wireless controller (AP), which worked without any issues.  In Aruba Central, the Guest SSID is setup with "Captive Portal" as its Security Level,  and is configured with the following settings:
    1
    ar
    When our clients connect to the SSID , they are only seeing the following:
    1
    What might be the reason that the Captive Portal page is not displaying the contents that I had previously had working prior to the shift to Central?  Thanks.
  • 2.  RE: Captive Portal Page Configuration Issue
    Posted 17 days ago
    Since you have Aruba Central why don't you use Aruba Central cloud guest instead of this approach.
    Here you can find more info on it
    Configuring a Guest Splash Page Profile
