Cloud Managed Networks
Central and problems to locate different features...
This thread has been viewed 16 times
  • 1.  Central and problems to locate different features...
    Posted 28 days ago
    I have problems to locate different features from Central... Can somebody give me hint what do I do wrong!
    My last issue is that I cannot find way to configure dhcp snooping to edge switches through Central groups.
    I found document (link below) but there is no such features what document says there should be...
    Configuring DHCP Snooping on Aruba Switches
    Document talks about to open "Networking Operations App"... As far as  I understood correct my landing page IS that page or do I need to "open" another page from somewhere? I can see few different things under Security but dhcp snooping is missing...
    Same thing with basic IGMP snooping/querier features....
    Jori Luoto
    AV-IT Specialist
  • 2.  RE: Central and problems to locate different features...
    Posted 27 days ago
    I would just use MultiEdit, as you'll have access to all the CLI commands.
  • 3.  RE: Central and problems to locate different features...
    Posted 27 days ago
    Yeah that I know but my client (and I too) seems to like quite easy on-boarding of devices through groups, easy way to add vlans to multiple devices with just couple of clicks etc from web GUI but where is the GUI way to enable IGMP Snooping for vlan or add dhcp snooping etc which are usually quite bulky stuff and not to mention that there is Aruba web documents which gives step-by-step manual how to do it but I just don't get it why I don't see those web gui components there?!?!?
    With multi-edit you need to remember to do something special to device before it is ready to go production and with templates you go even deeper to CLI so it will rise question about why they have bought system which could be replaced by NetEdit and way more cheaper lisences.
    This complaining is definetly off-topic and nobodys fault per-say but just want to give reason to my question :)
    Jori Luoto
    AV-IT Specialist
  • 4.  RE: Central and problems to locate different features...
    Posted 27 days ago
    I get it. I dont think currently there is a WebUI way of configuring IGMP/DHCP snooping for CX switches. I believe it will be there in the new Aruba Central.
