Aruba Apps
last person joined: 39 minutes ago
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
certificate based SSID issue
  • 1.  certificate based SSID issue
    Posted Jan 17, 2023 06:12 AM
    hi team,
    we have configured a certificate based SSID on aruba controller.
     user gets connected using certificate and everything is working fine but when user deletes the certificate from end device  its getting connected directly without certificate.
    is this normal behaviour ?
    please suggest.
  • 2.  RE: certificate based SSID issue
    Posted Jan 17, 2023 06:15 AM
    hi team,
    please suggest.
    i have attached the ssid configuration .
    Attachment(s)
    txt
    bel_employee.txt   2 KB 1 version
  • 3.  RE: certificate based SSID issue
    Posted Jan 23, 2023 05:55 AM
    The ssid is dot1x enabled rather than 'certificate based'.  You'll need to control the methods of authentication via the policy in your radius server.
  • 4.  RE: certificate based SSID issue
    Posted Jan 25, 2023 09:08 AM
    Separately, you should remove WPA and TKIP from your SSID profile.
    ryh
