Configure your SSID/Network to use a RADIUS server that handles the certificate authentication (EAP-TLS). ClearPass would be a good choice for that.
Alternatively, configure Cloud Auth under Global - Manage - Security - Authentication and Policy; if you have Azure AD or Google Workspace where your users are in.
Not recommended, but 'may work' is the following
configuration to do EAP-TLS directly on the AP. Mileage may vary.
Original Message:
Sent: Jul 19, 2022 01:09 AM
Subject: Certificate for validation and authentication for wireless users in Aruba Central
Hi Everyone,
Just wanted to check if there is an option in Aruba Central to use certificate for validation and authentication for wireless users. If there is an option, kindly share the documentations on how to enable this feature.
CM
