What channels and power do your APs end up on? If you have fewer channels, you will have more 'co-channel interference' and AirMatch will reduce power to improve that.
If you removed 40MHz channels and the AP switched to 80 or 160MHz, it makes sense that the power is reduced. If you removed 40MHz channels and all radios switch to 20MHz, I would expect the power to increase because of more available channels.
Channel and power selection can be a bit counterintuitive, so reaching out to your Aruba partner and have a look together may be worth as well.
Original Message:
Sent: May 22, 2023 05:03 PM
Subject: Channels and power
Hi guys!
Lately I've noticed that two of my APs working on lower dbms than they should and after excluding "+" channels ( 36+, 44+, ... etc. ) they started working on given range of power. I am just curious why using "+" channels decrease power of a signal?
Thanks.
