Clearpass and Catalyst 2960X - EAP-TLS timeout
  • 1.  Clearpass and Catalyst 2960X - EAP-TLS timeout
    Posted Mar 27, 2024 10:55 AM
    Hello Airheads,
    We are testing in our lab the integration of Clearpass and Cisco Catalyst 2960X for wired 802.1X authentication of Win11 Laptops.
    Everything works fine with EAP-PEAP, but when we switch the supplicant to EAP-TLS, we have RADIUS timeout logs in the access tracker. If we connect the same endpoint on an Aruba 2530 configured for 802.1X, EAP-TLS works fine.
    Clearpass version is 6.11.5 , Catalyst 2960X IOS version is the latest available, Endpoint device is Windows 11 Laptop with the latest patch.
    I just wanted to ask if anybody here succeeded in configuring the same environment with EAP-TLS with Cisco Catalyst 2960X and Clearpass, or if you have any suggestion to let it work.
    Thank you
    Kindly
    Alessandro
  • 2.  RE: Clearpass and Catalyst 2960X - EAP-TLS timeout
    Posted 29 days ago
    not per say, but a packet capture could be able to narrow it.
    fragmentation issue?
  • 3.  RE: Clearpass and Catalyst 2960X - EAP-TLS timeout
    Posted 29 days ago
    Hello and thank you,
    I don't think fragmentation could be a problem since we have the same MTU size on both Catalyst and HPE switches.
    Anyway I will take a PCAP from the port to investigate deeper.
    Kind regards
    Alessandro
