Create interfaces for each VLAN. If the switch is not acting as the router (or does not have Layer-3 capability), the VLANs and interface
commands must be passed to the router. The IP helper must be identified for the DHCP server and the ClearPass Policy Manager server for the DHCP request in order for the device to be profiled.
192.0.2.5 is the DHCP server and will vary based on the local configuration. 192.0.2.10 refers to the ClearPass Policy Manager
Cisco-switch(config)#interface vlan 333
Cisco-switch(config-if)# ip address 192.168.33.1 255.255.255.0
Cisco-switch(config-if)# ip helper-address 192.0.2.10
Cisco-switch(config-if)# ip helper-address 192.0.33.5
Cisco-switch(config-if)# exit
refer to the ClearPass Deployment Guide
David Mendoza
Original Message:
Sent: Feb 14, 2022 05:49 PM
Subject: Clearpass as IP Helper for DHCP clients on controller
Thanks , so based on my image.. how do I use dhcp as a server on the controller for clients in that vlan, as using for dhcp profiling CPPM removes the option for me to use it as server?
champion nweke
Original Message:
Sent: Feb 14, 2022 09:04 AM
clearpass cannot be used as a dhcp server to assign IP addresses to dhcp clients, ip helper points to clearpass for endpoint profiling.
tan xiaofeng
Original Message:
Sent: Feb 14, 2022 02:13 AM
Hi all,
I just needed to get an understanding as to how clearpass works as an IP helper for DHCP clients on a controller, as on the controller, when defining it for dhcp profiling it takes of the option of it being used as a server.
Does clearpass have an option to define DHCP scope? If not how do the clients in the vlan get IP?
Please see attached
champion nweke
