Aruba Apps
last person joined: 10 days ago
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
Clearpass captive portal ssid issue.
This thread has been viewed 43 times
  • 1.  Clearpass captive portal ssid issue.
    Posted Jan 10, 2023 02:03 AM
    hi team,
    we have two aruba 7200 controllers working as standalone .( controller 1 , controller 2) on 6.5.x.x version
    we have recently upgraded   controller 1 from 6.5.x.x to 8.6.x.x .
    we have created a  guest ssid from controller 2 on newly upgraded controller 1.
    user can connect to this guest ssid and redirect to url but url page is not opening . i guess i am missing some configuration part.
    i am attaching  both the configuration .( running config on controller 2 and guest ssid config on controller 1 ).
    on controller 2 same SSID is working properly .
    it would be really helpful if anyone can tell me  what configuration i am missing or what i am doing wrong .
    thanks ,
    Attachment(s)
  • 2.  RE: Clearpass captive portal ssid issue.
    Posted Jan 10, 2023 02:40 AM
    have you seen this viedeo? This helps in the Configuration - https://youtube.com/watch?v=F-4p7cqZzXQ&feature=shares
    Did I get it ight, on Controller 2 it works and on Controller 1 not? It would be good to paste the whole controller 1 config here.
    Why are you using downloadable rules:
    aaa profile "Guest@Bajaj"
       initial-role "Guest@Bajaj"
       download-role
    This is to Enables role download from ClearPass Policy Manager.
    Often made mistakes:
    - did the Controller have an IP Address in the Guest VLAN?
    - Certificate issues, ist there a public trusted certificate on the controller and the Cert Common Name placed in ClearPass Config?
  • 3.  RE: Clearpass captive portal ssid issue.
    Posted Jan 11, 2023 12:55 AM
    Hi cordless,
    I will check this and update you.
    During the upgradation we were facing low space on flash .
    I have tried everything available online to make some space but failed at last I run the command " wipe out flash" to format the controller.
    Do we need to install the certificates after this command.
  • 4.  RE: Clearpass captive portal ssid issue.
    Posted Jan 11, 2023 03:33 AM
    see description of the command here:
    https://www.arubanetworks.com/techdocs/CLI-Bank/Content/aos8/wipe.htm
    Yes you have to install Captive Portal Certificate afterwards. But that was a very drastic way.
    You should work with the community or TAC before doing so.
  • 5.  RE: Clearpass captive portal ssid issue.
    Posted Jan 11, 2023 03:41 AM
    Hi ,
    Actually we do not have the tac support for this .
    After this command i upgraded the firmware. Other psk based  SSIDs are working fine.
    Only having trouble with captive portal SSID.
    I have checked on the other working controller and found no certificates  but SSIDs are working on the controller .PFA .
  • 6.  RE: Clearpass captive portal ssid issue.
    Posted Jan 11, 2023 03:49 AM
    That is correct.
    If you are doing Captive Portal you will have to have a valid public trusted Certificate on the Controller. See the video linked in this thread.
  • 7.  RE: Clearpass captive portal ssid issue.
    Posted Jan 11, 2023 07:27 AM
    Hi ,
    When user connects to captive portal SSID , they are redirected to securelogin.arubanetworks.com/auth/cp_ disabled.html.
    I am attaching the snapshot.
    I have also captured the user log .
    It's showing authentication server request time-out.
    I am attaching the logs . please check if anyone can see the issue.
    Attachment(s)
    txt
    baja guest user logs.txt   38 KB 1 version
  • 8.  RE: Clearpass captive portal ssid issue.
    Posted Jan 11, 2023 07:52 AM
    Does your Controller can communicate with the Radius Server?
    I assume the Captive Portal will also be hosted on the ClearPass - if so, what is the Event Viewer and Access Tracker saying?
    show aaa authentication-server radius statistics
    show aaa authentication-server radius CPPM_GROUP
    show aaa authentication captive-portal <Captiveportalprifilename>
    ...gives more insight
    Be sure that the controller has an IP Interface in the Guest Client VLAN.
  • 9.  RE: Clearpass captive portal ssid issue.
    Posted May 25, 2023 09:55 AM
    Based on the given Web Search Results, it seems that you have two standalone Aruba 7200 controllers (Controller 1 and Controller 2) running on version 6.5.x.x [1]. Recently, you have upgraded Controller 1 to version 8.6.x.x and created a guest SSID from Controller 2 on the newly upgraded Controller 1 [1]. However, users are unable to open the URL page after connecting to the guest SSID, indicating a missing configuration. To troubleshoot the issue, you should compare the running configuration on Controller 2 with the guest SSID configuration on Controller 1 to identify any missing or incorrect configurations [1]. Additionally, the Aruba 7200 series Mobility Controllers have a new central processor that can support up to 32,000 mobile devices and perform stateful firewall policy enforcement at 40 Gbps [3]. The controllers can be centrally managed with Aruba AirWave network management, which can help you monitor and troubleshoot any issues with the network [3].
