Get the Operator Profile in use from the top-right menu:
Then under (Guest) -> Administration -> Operator Logins -> Profiles, select the Super Administrator (or profile you found in the previous step). Click on it and then click Edit.
Scroll to the bottom and find the Language selector, which you can change from 'Auto-detect' to your preferred language:
Original Message:
Sent: Mar 02, 2023 04:17 AM
Subject: Clearpass guest translation auto-translates admin portal too
I am configuring translations on the guest portal
When I select a language in the test page, clearpass automatically translates all pages, including the guest admin portal
Is there a way to disable the translation of the admin portal?
thanks
