last person joined: 9 hours ago
Clearpass Onguard problem
This thread has been viewed 42 times
  • 1.  Clearpass Onguard problem
    Posted 4 days ago
    Hello!
    Recently I have configured a basic Onguard - Posture policy on our Clearpass to check windows Firewall and some registry state. And it is working fine in general.
    But, during on the first WLAN connection of the day the User stucks in UNKOWN(0) posture state and had to rejoin to get in HEALTHY(0). Because the WLAN connection is faster than the Onguard scan, so during the first connection the Posture state is UNKOWN(0) and based on this the client gets the quarantine ACL.
    Example log:
    What am I missing? How can I configure this to change the client state based on the Posture state change?
  • 2.  RE: Clearpass Onguard problem
    Posted 4 days ago
  • 3.  RE: Clearpass Onguard problem
    Posted 3 days ago
    When using Onguard there is the following dependency:
    1. First WLAN dot.1x-Auth - Posture state is UNKOWN, because no status has yet been transmitted by the agent
    2. Web-Auth by the agent - posture status is transmitted, a port bounce must occur at this point so that the posture status can be evaluated.
    3. Second WLAN dot.1x-Auth - At this point, the dot.1x service must evaluate the posture code. However, it does not see it because the dot1x-wlan service and the web-auth service do not communicate with each other.
    The trick is to activate "Use Cached Results" in the Enforcement tab.
    Then the dot.1x-Auth service can read the posture code from the endpoint cache. Then everything works as desired.
    Waldemar
    ACCX # 1377, ACEP, ACX - Network Security
  • 4.  RE: Clearpass Onguard problem
    Posted yesterday
    The tricky part is that I have configured this feature already. (Based on the official guide)
    And yet the port bounce does not happens :(
    Do I have to configure something on the AP - WLAN side? like enable Dynamic Authorization?   I did it already, and did not solve it.
  • 5.  RE: Clearpass Onguard problem
    Posted yesterday
    Yes, I know, it's a difficult topic, but please don't give up.
    The port bounce does not happen automatically, you have to configure it. In the web-auth service you have to send either coa in a RADIUS_DynAuthZ or bounce-client in an agent-enforcement-profile. If you use coa, you must also set up Dynamic Authorization in the WLAN. With agent enforcement, the agent bounces the port on the client side independently of Dynamic Authorization. It's a matter of taste, I use the agent variant.
    Have you watched any videos of Herman? He explains it very well.
    https://m.youtube.com/watch?v=l5Rt2K8KJiE
    Waldemar
  • 6.  RE: Clearpass Onguard problem
    Posted 4 hours ago
    Yeah I viewed that video, and configured everything like Herman.
    Yet it seems the [ArubaOS Wireless - Terminate Session] enforcement profile has no effect, because after the Posture Scan, there is no connection bounce or anything like that.
    So I am clueless now.
  • 7.  RE: Clearpass Onguard problem
    Posted 4 minutes ago
    CoA is probably not working.
    Make sure that ClearPass and WLAN controller synchronize the original time with the same NTP server.
    Make sure that RADIUS CoA is enabled in the ClearPass network device.
    ClerPass uses UDP 3799 for CoA by default. Make sure that ClearPass can reach the controller via this port.
    Authorization Radius Authorization or RFC 3576 Server must also be configured in the WLAN controller.
    Please post enforcement from the web-auth service.
    Waldemar
