last person joined: 11 hours ago
ClearPass TACACS+ Dictionary for Opengear
This thread has been viewed 21 times
  • 1.  ClearPass TACACS+ Dictionary for Opengear
    Posted Feb 06, 2017 05:20 PM
    Hello all,
    I've created a custom TACACS+ dictionary that can be imported into ClearPass for administrative login into Opengear. It is attached to this post, but make sure you remove the .txt portion of the filename (this forum apparently does not allow .xml file type uploads).
    On Opengear, make sure to enable "Use Remote Groups" under Serial & Network -> Authentication. Then simply point Opengear to ClearPass. Nothing further to set up.
    The "groupname" attribute should be passed back to OpenGear from ClearPass and should match a local admin group that is defined on the Opengear under Serial & Network -> Users & Groups.
    Enjoy!
  • 2.  RE: ClearPass TACACS+ Dictionary for Opengear
    Posted Jun 20, 2017 02:43 AM
    Hi Tim, can you create one for Silver Peak?
  • 3.  RE: ClearPass TACACS+ Dictionary for Opengear
    Posted Apr 18, 2018 12:23 PM
    Perfect! Just what I needed, worked slick :-D
  • 4.  RE: ClearPass TACACS+ Dictionary for Opengear
    Posted May 15, 2023 12:47 PM
    Thank you for dictionary, I am able to Authenticate without issues but Authorization keep failing. I am getting message that raccess is not enabled, Screenshots below are from Access Tracker session details:
    Appreciate any help you can provide.
  • 5.  RE: ClearPass TACACS+ Dictionary for Opengear
    Posted Dec 18, 2023 07:33 AM
    Thanks a lot for this!
