I know there is an internal document in Forcepoint for ClearPass integration:
But unfortunately, I'm not sure if I am allowed to share that. Can you check with your Forcepoint contacts?
Original Message:
Sent: Jan 30, 2023 01:56 PM
Subject: ClearPass/Forcepoint Health Check for remote users
Hello mates,
I hope all is well.
I am new to clearpass and Onguard, and I would like to deploy a scenario which is the following:
I have remote users connecting to the network through VPN access (forcepoint vpn), and I would like to check their compliance using OnGuard agent. The access will be granted if they're healthy, and if they're not the session will be terminated.
Anyone can help about the steps needed to be done and the workflow of this integration?
Thank you
