Command for switches to see inactive ports
  • 1.  Command for switches to see inactive ports
    Posted 28 days ago
    Hello colleagues,
    do you know a command to see how long switchports are already inactive or what time they were active the last time?
    I have following switches:
    • HP J9851A Switch 5412Rzl2
    • Aruba JL357A 2540-48G-PoE+-4SFP+ Switch
    Maybe this is not possible to see?
    Thank you!
  • 2.  RE: Command for switches to see inactive ports
    Posted 27 days ago
    What do you mean by "inactive"?  From a physical connection standpoint?  From an authentication standpoint?  Admin down?  Something else?
  • 3.  RE: Command for switches to see inactive ports
    Posted 27 days ago
    What do you mean by "inactive"?  Authentication?  Physical link?  Admin down?  Something else?
  • 4.  RE: Command for switches to see inactive ports
    Posted 27 days ago
    A proper network management tool should keep track of this.
    One open source solution I've been using for some years now, is Netdisco. You could spin this up quickly on a VM. There are docker containers, but had issues updating it last time I tried, so reverted back to setting up its own instance.  netdisco.org
  • 5.  RE: Command for switches to see inactive ports
    Posted 25 days ago
    Comware switch will show you when it transition last time.
    GigabitEthernet1/0/2
    Current state: DOWN
    Line protocol state: DOWN
    Last link flapping: 27 weeks 3 days 7 hours 3 minutes<
    Last clearing of counters: Never
    Current system time:2024-05-03 14:02:18
    Last time when physical state changed to up:2023-10-23 13:57:00
    Last time when physical state changed to down:2023-10-24 07:02:52
    For 2540 you can check logs  with
    show log -r | include ports
    In both cases you need to parse the output. Comware is more reliable as logs on ArubaOS-S switches will roll over.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
