Well, on my side, copper SFPs are used to successfully connect servers (on 5510 switches)
Maybe the problem is on the client side ? (since you already tried different patch cords, with no success)
How much time do you wait for the link to go up ? Is STP (any flavor) active on the switches ?
Original Message:
Sent: Feb 16, 2024 12:16 AM
Subject: Compatability of 5130 EI and 5140 EI IRF switches and JD089B SFP RF-45 transceiver
As suggested, i tried putting the RJ45 transceivers into 2 SFP ports on the same IRF switch member (this time combo port 1/0/19 and 1/0/20) and connected an ethernet cable between them. BOOM. > link light/activity on the SFP ports > console displayed:
%Feb 16 14:21:57:316 2024 xxx IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/20 changed to up.
%Feb 16 14:21:57:322 2024 xxx IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/20 changed to up.
%Feb 16 14:21:57:414 2024 xxx STP/6/STP_DETECTED_TC: Instance 0's port GigabitEthernet1/0/19 detected a topology change.
%Feb 16 14:21:57:430 2024 xxx IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/19 changed to up.
%Feb 16 14:21:57:463 2024 xxx IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/19 changed to up.
I also then tried between this member 1 IRF switch and another member 1 IRF switch, and i also got line/protocol UP.
Thus, it seems that these transceivers can only be used for connecting between switches, not for end device connectivity (pcs/servers). Unless there is a specific setting that needs to be set on the pc/server NIC that i am unaware of. Maybe there is some particular protocol that they use that requires them to be used as pairs. Admittedly, i havent yet tried using this SFP RJ-45 transceiver to connect direct to another standard RJ-45 ethernet port (to eliminate as to whether they need to be used in pairs or not). I primarily bought these for connecting some pcs to this switch, not for switch-to-switch connections, thus i may need to just build an auxiliary switch for this purpose.
If anyone has one of these RJ45 (JD089B) transceivers and has a chance, can they try connecting one to either a 5130/5140 SFP/IRF switch and see if they can get simple connectivity/link to a pc/server.
James
Original Message:
Sent: Feb 14, 2024 08:08 AM
Hi James
That's weird because JD089B is clearly officially supported !
And Comware is really permissive ! I managed to use roughly any SFP (whatever vendor) in this kind of switches.
Did you try, as Ian proposed "to put two in a single switch and put a cable between them " (but in the SFP slots , not SFP+) ?
or between 1 SFP T (g1/0/19) and port g1/0/18 ?
(STP should block one, but link and protocol should be up)
Did you try to open a case on Aruba Support Portal ?
Frederic MEUNIER
Original Message:
Sent: Feb 13, 2024 04:33 PM
yes, i have tried all 3:
combo enable auto
combo enable fiber
combo enable copper
without any success
Original Message:
Sent: Feb 13, 2024 04:38 AM
Hi James
Did you try to force the combo ?
"combo enable fiber" (to force using the SFP)
Frederic MEUNIER
Original Message:
Sent: Feb 12, 2024 07:41 PM
Hi Frederic,
Output below:
<xxx>dis curr int GigabitEthernet 1/0/19
port link-mode bridge
port access vlan xxx
combo enable auto
return
<xxx>
have also included the all command below:
[xxx]dis curr int GigabitEthernet 1/0/19 all
description GigabitEthernet1/0/19 Interface
enable snmp trap updown
enable log updown
undo bandwidth
undo evb enable
evb vdp timer resource-wait-delay exponent 20
evb vdp timer keepalive exponent 20
port link-type access
undo port outbound-vlan-tag enable
undo vlan mapping nni
undo port private-vlan
voice-vlan qos 6 46
voice-vlan mode auto
undo voice-vlan enable
undo mac-vlan enable
undo mac-vlan trigger enable
undo port pvid forbidden
combo enable auto
mdix-mode automdix
speed auto
speed auto downgrade
duplex auto
undo loopback
transceiver tx-enable
undo source-interface
undo shutdown
undo port-isolate enable
undo link-delay down
undo link-delay up
undo port link-flap protect enable
undo storm-constrain broadcast
undo storm-constrain multicast
undo storm-constrain unicast
undo storm-constrain control
storm-constrain enable trap
storm-constrain enable log
undo port auto-power-down
undo port up-mode
undo priority-flow-control
undo priority-flow-control no-drop dot1p
undo priority-flow-control dscp-mapping
jumboframe enable 10000
flow-interval 300
undo flow-control
undo eee enable
undo dampening
broadcast-suppression 100
multicast-suppression 100
unicast-suppression 100
unicast-suppression 100 known
undo bpdu-drop any
undo macsec desire
macsec include-sci
undo macsec maintenance-mode enable
undo mka apply policy
macsec confidentiality-offset 0
macsec replay-protection enable
macsec replay-protection window-size 0
macsec validation mode check
undo mka enable
mka priority 0
undo mka psk
macsec cipher-suite gcm-aes-128
mka timer mka-life 6
undo port ifmonitor crc-error
undo port ifmonitor input-error
undo port ifmonitor output-error
undo port ifmonitor rx-pause
undo port ifmonitor tx-pause
undo port ifmonitor sdh-error
undo port ifmonitor sdh-b1-error
undo port ifmonitor sdh-b2-error
undo port ifmonitor input-usage
undo port ifmonitor output-usage
crc-error bit-error-ratio transfer-protocol bfd
undo igmp-snooping fast-leave
undo igmp-snooping overflow-replace
undo igmp-snooping source-deny
undo port multicast-vlan
undo igmp-snooping router-port-deny
undo igmp-snooping group-limit
undo igmp-snooping group-policy
undo igmp-snooping static-router-port all
undo igmp-snooping static-group all
undo igmp-snooping host-join all
stp enable
undo stp root-protection
undo stp loop-protection
stp loopback-protection
undo stp edged-port
undo stp no-agreement-check
undo stp config-digest-snooping
undo stp tc-restriction
undo stp role-restriction
stp compliance auto
stp transmit-limit 10
stp point-to-point auto
undo stp port bpdu-protection
undo stp port bpdu-filter
lldp enable
lldp compliance admin-status cdp disable
undo lldp encapsulation
undo lldp check-change-interval
undo lldp management-address-format
lldp admin-status txrx
undo lldp tlv-config basic-tlv port-id
undo cdp voice-vlan
undo lldp source-mac vlan
undo lldp management-address arp-learning
undo lldp management-address nd-learning
undo lldp notification remote-change enable
undo lldp notification med-topology-change enable
lldp tlv-enable basic-tlv port-description
lldp tlv-enable basic-tlv system-name
lldp tlv-enable basic-tlv system-description
lldp tlv-enable basic-tlv system-capability
undo lldp tlv-enable dot1-tlv dcbx
lldp tlv-enable dot1-tlv port-vlan-id
undo lldp tlv-enable dot1-tlv protocol-vlan-id
undo lldp tlv-enable dot1-tlv vlan-name
undo lldp tlv-enable dot1-tlv management-vid
lldp tlv-enable dot1-tlv link-aggregation
undo lldp tlv-enable dot1-tlv congestion-notification
undo lldp tlv-enable dot1-tlv evb
lldp tlv-enable dot3-tlv mac-physic
lldp tlv-enable dot3-tlv power
lldp tlv-enable dot3-tlv max-frame-size
undo lldp tlv-enable dot3-tlv eee
lldp tlv-enable med-tlv capability
lldp tlv-enable med-tlv network-policy
lldp tlv-enable med-tlv power-over-ethernet
lldp tlv-enable med-tlv inventory
undo lldp tlv-enable dot3-tlv link-aggregation
undo lldp agent nearest-nontpmr encapsulation
undo lldp agent nearest-nontpmr check-change-interval
undo lldp agent nearest-nontpmr management-address-format
lldp agent nearest-nontpmr admin-status disable
undo lldp agent nearest-nontpmr notification remote-change enable
undo lldp agent nearest-nontpmr tlv-enable basic-tlv port-description
undo lldp agent nearest-nontpmr tlv-enable basic-tlv system-name
undo lldp agent nearest-nontpmr tlv-enable basic-tlv system-description
undo lldp agent nearest-nontpmr tlv-enable basic-tlv system-capability
undo lldp agent nearest-nontpmr tlv-enable dot1-tlv dcbx
undo lldp agent nearest-nontpmr tlv-enable dot1-tlv port-vlan-id
undo lldp agent nearest-nontpmr tlv-enable dot1-tlv link-aggregation
undo lldp agent nearest-nontpmr tlv-enable dot1-tlv congestion-notification
lldp agent nearest-nontpmr tlv-enable dot1-tlv evb
undo lldp agent nearest-nontpmr tlv-enable dot3-tlv mac-physic
undo lldp agent nearest-nontpmr tlv-enable dot3-tlv power
undo lldp agent nearest-nontpmr tlv-enable dot3-tlv max-frame-size
undo lldp agent nearest-nontpmr tlv-enable dot3-tlv eee
undo lldp agent nearest-nontpmr tlv-enable med-tlv capability
undo lldp agent nearest-nontpmr tlv-enable med-tlv network-policy
undo lldp agent nearest-nontpmr tlv-enable med-tlv power-over-ethernet
undo lldp agent nearest-nontpmr tlv-enable med-tlv inventory
undo lldp agent nearest-nontpmr tlv-enable dot3-tlv link-aggregation
undo lldp agent nearest-customer encapsulation
undo lldp agent nearest-customer check-change-interval
undo lldp agent nearest-customer management-address-format
lldp agent nearest-customer admin-status disable
undo lldp agent nearest-customer notification remote-change enable
lldp agent nearest-customer tlv-enable basic-tlv port-description
lldp agent nearest-customer tlv-enable basic-tlv system-name
lldp agent nearest-customer tlv-enable basic-tlv system-description
lldp agent nearest-customer tlv-enable basic-tlv system-capability
undo lldp agent nearest-customer tlv-enable dot1-tlv dcbx
lldp agent nearest-customer tlv-enable dot1-tlv port-vlan-id
lldp agent nearest-customer tlv-enable dot1-tlv link-aggregation
undo lldp agent nearest-customer tlv-enable dot1-tlv congestion-notification
undo lldp agent nearest-customer tlv-enable dot1-tlv evb
undo lldp agent nearest-customer tlv-enable dot3-tlv mac-physic
undo lldp agent nearest-customer tlv-enable dot3-tlv power
undo lldp agent nearest-customer tlv-enable dot3-tlv max-frame-size
undo lldp agent nearest-customer tlv-enable dot3-tlv eee
undo lldp agent nearest-customer tlv-enable med-tlv capability
undo lldp agent nearest-customer tlv-enable med-tlv network-policy
undo lldp agent nearest-customer tlv-enable med-tlv power-over-ethernet
undo lldp agent nearest-customer tlv-enable med-tlv inventory
undo lldp agent nearest-customer tlv-enable dot3-tlv link-aggregation
qos priority 0
qos wrr weight
qos wrr be group 1 weight 1
qos wrr af1 group 1 weight 2
qos wrr af2 group 1 weight 3
qos wrr af3 group 1 weight 4
qos wrr af4 group 1 weight 5
qos wrr ef group 1 weight 9
qos wrr cs6 group 1 weight 13
qos wrr cs7 group 1 weight 15
link-aggregation port-priority 32768
undo lacp period
undo lacp mode
undo lacp transparent enable
return
[xxx]
James
Original Message:
Sent: Feb 12, 2024 03:51 AM
Hi James
Can you post the result of "display curr int g1/0/19"
Frederic MEUNIER
Original Message:
Sent: Feb 11, 2024 04:58 PM
Hi Ian/Frmeunier,
I tried inserting the transceiver into the SFP+ port, setting link speed to 1Gbps, but still no link/activity.
In regards to testing (this is on a 5140 24G 4SFP+ 1-slot HI 2-member IRF switch), i had the pc plugged into ethernet port 1/0/18 (combo port) and ran dis int:
<xxx>dis int GigabitEthernet 1/0/18
GigabitEthernet1/0/18
Current state: UP
Line protocol state: UP
IP packet frame type: Ethernet II, hardware address: 5477-8a79-xxxx
Description: xxx
Bandwidth: 1000000 kbps
Loopback is not set
Media type is twisted pair
Port hardware type is 1000_BASE_T
1000Mbps-speed mode, full-duplex mode
Link speed type is autonegotiation, link duplex type is autonegotiation
Flow-control is not enabled
Maximum frame length: 10000
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
Known-unicast max-ratio: 100%
PVID: xxx
MDI type: Automdix
Port link-type: Access
Tagged VLANs: None
Untagged VLANs: xxx
Port priority: 0
Last link flapping: 0 hours 4 minutes 56 seconds
Last clearing of counters: Never
Current system time:2024-02-09 14:17:10 Brisbane+10:00:00
Last time when physical state changed to up:2024-02-09 14:12:14 Brisbane+10:00:00
Last time when physical state changed to down:2024-02-09 14:12:11 Brisbane+10:00:00
Peak input rate: 159 bytes/sec, at 2024-02-09 14:16:30
Peak output rate: 93 bytes/sec, at 2024-02-09 14:16:25
Last 300 seconds input: 1 packets/sec 127 bytes/sec 0%
Last 300 seconds output: 0 packets/sec 87 bytes/sec 0%
Input (total): 751 packets, 54491 bytes
0 unicasts, 629 broadcasts, 122 multicasts, 0 pauses
Input (normal): 751 packets, - bytes
Input: 0 input errors, 0 runts, 0 giants, 0 throttles
0 CRC, 0 frame, - overruns, 0 aborts
- ignored, - parity errors
Output (total): 210 packets, 33618 bytes
0 unicasts, 0 broadcasts, 210 multicasts, 0 pauses
Output (normal): 210 packets, - bytes
Output: 0 output errors, - underruns, - buffer failures
0 aborts, 0 deferred, 0 collisions, 0 late collisions
0 lost carrier, - no carrier
IPv4 traffic statistics:
Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec
Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec
Input: 0 packets, 0 bytes
Output: 0 packets, 0 bytes
IPv6 traffic statistics:
i then inserted the RJ-45 SFP transceiver into 1/0/19 (fibre combo port) and seen the following on the console:
<xxx>%Feb 9 14:20:00:901 2024 xxx OPTMOD/4/MODULE_IN: GigabitEthernet1/0/19: The transceiver is 1000_BASE_T_AN_SFP.
i then ran dis int for port 19 and got:
<xxx>dis int GigabitEthernet 1/0/19
Current state: DOWN
Line protocol state: DOWN
Description: GigabitEthernet1/0/19 Interface
Loopback is not set
Media type is twisted pair, Port hardware type is 1000_BASE_T_AN_SFP
Unknown-speed mode, unknown-duplex mode
PVID: xxx
MDI type: Automdix
Tagged VLANs: None
Untagged VLANs: xxx
Port priority: 0
Last link flapping: Never
Current system time:2024-02-09 14:20:53 Brisbane+10:00:00
Last time when physical state changed to up:-
Last time when physical state changed to down:2024-02-07 01:49:14 Brisbane+10:00:00
Peak input rate: 0 bytes/sec, at 2024-02-07 11:52:10
Peak output rate: 0 bytes/sec, at 2024-02-07 11:52:10
Last 300 seconds input: 0 packets/sec 0 bytes/sec -%
Last 300 seconds output: 0 packets/sec 0 bytes/sec -%
Input (total): 0 packets, 0 bytes
0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses
Input (normal): 0 packets, - bytes
Output (total): 0 packets, 0 bytes
Output (normal): 0 packets, - bytes
i then moved the current ethernet cable for the pc from ethernet combo port 18 to the fibre-to-RF45 SFP fibre combo port 19 and ran dis int
<xxx>%Feb 9 14:22:04:739 2024 xxx IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/18 changed to down.
%Feb 9 14:22:04:744 2024 xxx IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/18 changed to down.
Current state: DOWN
Loopback is not set
PVID: xxx
MDI type: Automdix
Tagged VLANs: None
Untagged VLANs: xxx
Port priority: 0
Current system time:2024-02-09 14:23:12 Brisbane+10:00:00
As you can see the switch recognises the transceiver when inserted, but just does not bring up a link when an ethernet cable is inserted. I also tested a single brand new 5140 24G SFP 4SFP+ EI switch without any config/latest firmware on it, and got the same result
Current firmware on IRF is most current release:
<xxx>dis version
HPE Comware Software, Version 7.1.070, Release 6628P43
Copyright (c) 2010-2023 Hewlett Packard Enterprise Development LP
HPE 5140 24G 4SFP+ 1-slot HI Sw R9L61A uptime is 0 weeks, 2 days, 16 hours, 57 minutes
Last reboot reason : User reboot
Boot image: flash:/5140hi-cmw710-boot-r6628p43.bin
Boot image version: 7.1.070, Release 6628P43
Compiled Aug 10 2023 11:00:00
System image: flash:/5140hi-cmw710-system-r6628p43.bin
System image version: 7.1.070, Release 6628P43
Feature image(s) list:
flash:/5140hi-cmw710-freeradius-r6628p43.bin, version: 7.1.070, Release 6628P43
Slot 1:
Uptime is 0 weeks,2 days,16 hours,57 minutes
5140 24G 4SFP+ 1-slot HI Sw with 2 Processors
BOARD TYPE: 5140 24G 4SFP+ 1-slot HI Sw
DRAM: 2048M bytes
FLASH: 512M bytes
PCB 1 Version: VER.B
Bootrom Version: 121
CPLD 1 Version: 002
Release Version: HPE 5140 24G 4SFP+ 1-slot HI Sw R9L61A-6628P43
Patch Version : None
Reboot Cause : UserReboot
[SubSlot 0] 16GE+8COMBO+4SFP Plus
Slot 2:
DRAM: 2048M bytes
FLASH: 512M bytes
CPLD 1 Version: 002
<xxx>
Original Message:
Sent: Feb 06, 2024 05:33 AM
Hello
I have 5510 models that accept and use 1GBase-T SFPs with no problem :
display inter g1/0/11GigabitEthernet1/0/11Current state: UPLine protocol state: UPIP packet frame type: Ethernet II, hardware address: 943f-c248-xxxxDescription: "xxxxx"Bandwidth: 1000000 kbpsLoopback is not setMedia type is twisted pair, Port hardware type is 1000_BASE_T_AN_SFP1000Mbps-speed mode, full-duplex modeLink speed type is autonegotiation, link duplex type is autonegotiation
can you give us the "display interface" when SFP inserted and cable plugged in ?
What firmware version do you use ?
Frederic MEUNIER
Original Message:
Sent: Feb 05, 2024 05:32 PM
Hi All,
I am having issues getting a JD089B SFP RJ-45 transceiver working on either a 5130 EI or 5140 EI IRF stack. I have tried on both normal SFP port (on the 5130 EI) as well as combo port (on the 5140 EI) with no luck. Has anyone else had this issue.
The transceiver is recognised when inserted (line protocol UP shown within the console) and running display transceiver interface shows the following info (from a 5130-24G-SFP-4SFP+ EI switch
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/4475ada51ba04330ab85df299a0cf001.png)
However when i plug an ethernet cable from a pc to the transceiver, no link lights come up. I have tried enabling/disabling the interface, changing MDI/MDIX mode, setting link speed to 1Gb/100Mb, and on the combo port changing mode to copper/fibre/auto without any luck. Have tried Cat6A, Cat6 and Cat5e cables, both straight through and cross-over with no luck.
The transceivers are below. I have bought and inserted 8 of them, and cannot get 2 of them working. I havent tried the other 6, but i wouldnt think all 8 are faulty. Possibly some compatibility issue (although product specifications say the JD089B is compatible transceiver for the 5130/5140 switches). Any help resolving this issue would be appreciated
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/a3905449617542f19365bf91a7baa52e.jpg)
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/947bfb9c83ae4c929dac62db243c0621.jpg)
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/f954a4c379cf4798a8b12e5a67ce3497.jpg)
James
