Have you enabled ClientMatch? That should improve this as well.
Clients will make their own decision on which AP (and radio 2.4/5/6GHz) they will connect, and most clients will connect to the SSID with the 'best performance', which means that if you have a very strong 2.4GHz signal, they may tend to connect to 2.4 while you want them on 5GHz. But if you have wider channels on 5GHz, and the received signal is comparable, the client may chose the 5GHz. As a generic guidance, set the power-level on 2.4GHz at least 6dB lower than your 5GHz radio if you see that clients stick to 2.4GHz. Also, don't mix channel widths on the same band. Make sure all 2.4GHz channels are 20MHz, and for 5GHz it probably would be 40MHz if you have 13 APs and enough coverage to lower the power. Then there also clients that once connected, they will never move unless the signal becomes really poor, and then they will roam. That means, it would help if you can find out if it's specific clients, if those are stationary or moving. And sometimes it may be better for a client to connect to a distant AP if the signal is strong enough and there is less interference or less channel utilization. If connecting to a far away AP also results in low connection speed, then there is an issue you could address.
Have you seen
this document about optimizing roaming? If enabling ClientMatch and the hints in this document don't improve, please work with your Aruba partner or Aruba support.
Original Message:
Sent: Feb 04, 2023 04:12 PM
Subject: Connect Clients to Closest Access Point
Hello guys,
I have done quick search to find my question. but I couldn't find proper solution. I have a building with 13 AP-515. All the APs are manages by Aruba Central. some of my clients are trying to connect to the access point far away while another access point is mounted around 5 meter to the client.
I have tried to decrease tx-power to decrease overlap coverage. but still some clients trying to connect to far APs!!!
Please advise me how I can fix this issue.
Thanks in advance
