Wired Intelligent Edge
Console connection Aruba 6100 over AUX Port
This thread has been viewed 46 times
  • 1.  Console connection Aruba 6100 over AUX Port
    Posted Mar 22, 2024 10:34 AM
    Hey folks
    I support a company that has some Aruba 6100 switches in use.
    With this model, console access is solved via USB-C.
    I usually use Moxa NPort Serial Device Server for remote access to the console.
    Unfortunately, this doesn't work with these switches because they don't have a regular console port.
    Is there a way to do this?
    Best regards,
    Erwin
  • 2.  RE: Console connection Aruba 6100 over AUX Port
    Posted Mar 22, 2024 11:26 AM
    There a few different cable pin-out conversion options:
    HPE Aruba Networking USB-A to RJ45 PC-to-Switch Cable (R9G48B)
    HPE Aruba Networking USB-A to RJ45 PIN3TX-6RX Cable (R8Z87A)
    We regularly used these cable in our internal lab with Lantronix Console Servers
    Here is a thread where a few different console options are discussed:
    Aruba CX USB Console Server
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 3.  RE: Console connection Aruba 6100 over AUX Port
    Posted Mar 25, 2024 04:11 AM
    Hello 802.zak
    Thanks for your answer.
    The customer has already ordered the following cable: https://www.aten.com/global/en/products/usb-solutions/converters/uc232b/
    Does it work with that too?
  • 4.  RE: Console connection Aruba 6100 over AUX Port
    Posted Mar 25, 2024 10:25 AM
    I have not personally used that cable. But I have heard of people successfully using ATEN cables.
    Zak Chalupka
    wifizak@hpe.com
  • 5.  RE: Console connection Aruba 6100 over AUX Port
    Posted Mar 26, 2024 03:31 AM
    Hello 802.zak
    Do I have to activate the console on the AUX port or is it always active?
    I can't get it to work.
    Switch: Aruba 6100
    Thank you for your help.
  • 6.  RE: Console connection Aruba 6100 over AUX Port
    Posted Mar 27, 2024 07:27 AM
    For the ATEN UC232B Cable to work you need to use a rollover adapter in addition. See the blue adapter in the USB console connectivity option picture below.
  • 7.  RE: Console connection Aruba 6100 over AUX Port
    Posted 12 days ago
    What options do I have is my terminal server has USB A connections? I can connect to multiple RJ45 console ports using standard Cisco cables. However, looking at the options above, there is nothing that supports USB A to USB A.
