Convert IAP without Controller
  • 1.  Convert IAP without Controller
    Posted May 15, 2024 09:52 AM
    I would like to know if it is possible to convert an IAP-305-RW terminal to "standalone" mode without the controller on which it is declared?
    When I connect to its web interface, the connection is refused.
    In my opinion, when a terminal is managed by a controller, it's impossible to do anything on it without the controller, but I'd like to be sure.
    Same question with an IAP-205-RW ...
    Thanks in advance for your reply.
    Laetitia.
    TELLIER-LAROUANNE Laetitia
  • 2.  RE: Convert IAP without Controller
    Posted May 15, 2024 11:02 AM
    The IAP is currently operating as a campus AP with a mobility controller?  If that is the case then you can factory reset the IAP which should load the original IAP software which allows for operation without a mobility controller.
    Carson Hulcher, ACEX#110
