CPPM Intune Extension v5 to v6
  • 1.  CPPM Intune Extension v5 to v6
    Posted 28 days ago
    I've been having some issues using the Intune extension and noticed there is a new version. Is this "upgrade" as simple as stopping v5, installing v6, adding in the same config values from v5 and then starting up v6? Is this just populating the endpoint DB anyway?
    -Mike
  • 2.  RE: CPPM Intune Extension v5 to v6
    Posted 11 days ago
    I would check the Intune integration Guide, and double-check the API permissions required before you blindly migrate. Conceptually v5 to v6 should be pretty similar and migration may be as simple as you describe.
