I think that cannot be done through the GUI. Please reach out to Aruba TAC to report the issue. If it is a large number of switches, they might find a way to get the commands inserted through the API.
If it is a handful of switches, you could connect to the switch, enter central-support-mode, issue the commands to disable telnet and http-web, then disable support mode again:
sw00(config)# aruba-central support-mode enable
sw00(config)# no telnet-server
sw00(config)# no web-management plaintext
sw00(config)# aruba-central support-mode disable
The config should stay there even after central takes management control again.
Original Message:
Sent: Nov 18, 2022 12:06 AM
Subject: Disable Web Interface on Switches from Central
Hi all,
I was hoping someone can answer a question for me:
How do you disable the (HTTP )WebUI and Telnet on AOS-S switches from Aruba Central? It's very simple on Central-Managed Access Points, you do it from Config>System:
