Display hostname on access tracker using TEAP authentication and DUR
  • 1.  Display hostname on access tracker using TEAP authentication and DUR
    Posted 5 days ago
    Team,
    Looking for some help here,
    I am able to successfully display hostname by adding a "Radius:IETF User-Name  = %{Authentication:TEAP-Method-2-Username}" command to the standard clearpass enforcement profile, however, I am unable to see where I can introduce this command to the DUR enforcement profile.  Is this possible?
    Con
    Stathis
  • 2.  RE: Display hostname on access tracker using TEAP authentication and DUR
    Posted 5 days ago
    You would not introduce this to your DUR enforcement profile. In your enforcement policy just apply two different profiles, one for the IETF User-Name, and one for the Role (or Downloadable User Role/DUR).
  • 3.  RE: Display hostname on access tracker using TEAP authentication and DUR
    Posted 4 days ago
    Thanks Herman, I applied the second profile and the switch is now showing user name as expected.  I am not able to see the hostname in access tracker after a successful TEAP method 1 auth.  Any ideas?  Ive spent some time on this and now am stuck
    Con
    Stathis
  • 4.  RE: Display hostname on access tracker using TEAP authentication and DUR
    Posted 4 days ago
    Why does the RADIUS response section show that you are returning Radius:IETF:User-Name twice?
    Carson Hulcher, ACEX#110
  • 5.  RE: Display hostname on access tracker using TEAP authentication and DUR
    Posted 2 days ago
    I assume you have two different enforcement profiles for user+machine auth and just machine auth?
    If so, you need to update your enforcement for the machine auth to send the computer name as the Radius:IETF:User-Name and the user+machine auth to send the user-name as the teap method-2.
    In your picture you are sending Radius:IETF:User-Name twice.  You have an enforcement profile applied that is trying to send Radius:IETF:User-Name =""
    This is causing you an issue because you can not send the same RADIUS attribute with two different values - even if that value is NULL.
    I had to work around this same thing - I wish Clearpass had the ability to understand if you had multiple radius values that are NULL and send the one that actually had a value.
    I had to create some SQL logic so that I don't have 8 different Return-User-Name enforcement profiles for different reasons.
