Display hostname on access tracker using TEAP authentication and DUR
This thread has been viewed 28 times
  • 1.  Display hostname on access tracker using TEAP authentication and DUR
    Posted Jun 26, 2024 03:36 AM
    Team,
    Looking for some help here,
    I am able to successfully display hostname by adding a "Radius:IETF User-Name  = %{Authentication:TEAP-Method-2-Username}" command to the standard clearpass enforcement profile, however, I am unable to see where I can introduce this command to the DUR enforcement profile.  Is this possible?
    Con
    Stathis
  • 2.  RE: Display hostname on access tracker using TEAP authentication and DUR
    Posted Jun 26, 2024 11:40 AM
    You would not introduce this to your DUR enforcement profile. In your enforcement policy just apply two different profiles, one for the IETF User-Name, and one for the Role (or Downloadable User Role/DUR).
  • 3.  RE: Display hostname on access tracker using TEAP authentication and DUR
    Posted Jun 26, 2024 07:38 PM
    Thanks Herman, I applied the second profile and the switch is now showing user name as expected.  I am not able to see the hostname in access tracker after a successful TEAP method 1 auth.  Any ideas?  Ive spent some time on this and now am stuck
    Con
    Stathis
  • 4.  RE: Display hostname on access tracker using TEAP authentication and DUR
    Posted Jun 27, 2024 10:22 AM
    Why does the RADIUS response section show that you are returning Radius:IETF:User-Name twice?
    Carson Hulcher, ACEX#110
  • 5.  RE: Display hostname on access tracker using TEAP authentication and DUR
    Posted Jun 28, 2024 01:32 PM
    I assume you have two different enforcement profiles for user+machine auth and just machine auth?
    If so, you need to update your enforcement for the machine auth to send the computer name as the Radius:IETF:User-Name and the user+machine auth to send the user-name as the teap method-2.
    In your picture you are sending Radius:IETF:User-Name twice.  You have an enforcement profile applied that is trying to send Radius:IETF:User-Name =""
    This is causing you an issue because you can not send the same RADIUS attribute with two different values - even if that value is NULL.
    I had to work around this same thing - I wish Clearpass had the ability to understand if you had multiple radius values that are NULL and send the one that actually had a value.
    I had to create some SQL logic so that I don't have 8 different Return-User-Name enforcement profiles for different reasons.
  • 6.  RE: Display hostname on access tracker using TEAP authentication and DUR
    Posted 29 days ago
    Can you share the SQL logic you created to be able to reduce the number of profiles for returning the username?
    Sounds like an interesting solution
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 7.  RE: Display hostname on access tracker using TEAP authentication and DUR
    Posted 5 days ago
    Thanks guys for your response, apologies for the tardiness of my reply, I did resolve my issue thanks to your input - I was looking in the wrong places.  I ended up creating two additional enforcement profiles, one for TEAP-1 and the other for TEAP-2 and applying them to the enforcement policy.  This did the trick - see below.
    Thanks Guys
    Con
    Stathis
