EAP-TLS authentication method setting - authorization required
This thread has been viewed 51 times
  • 1.  EAP-TLS authentication method setting - authorization required
    MVP
    Posted Mar 22, 2024 12:19 PM
    Would like to verify what this setting is actually checking. Doing my research on this checkbox, I thought this would check if the user account associated with the cert was disabled in AD. However in my testing of a disabled user account, I am still able to fully authenticate (with authZ) with the cert.
    In my auth source, when testing the attribute query for this test user, I can see AD is returning that the account is disabled:
    I thought havinge the Authorization Required checkbox checked would be enough for the radius request to fail given the user account is disabled. Am I wrong?
    Do I need to add additional authZ rules checking for the various userAccoundControl values associated with disabled accounts?
  • 2.  RE: EAP-TLS authentication method setting - authorization required
    Posted Mar 24, 2024 02:56 AM
    see if this answers it
    eap-tls-authorization-required
  • 3.  RE: EAP-TLS authentication method setting - authorization required
    MVP
    Posted 29 days ago
    I have tried the two filters below:
    (|(&(sAMAccountName=%{Authentication:Username})(objectClass=user))(&(userPrincipalName=%{Authentication:Username})(objectClass=user)))
    (&(objectClass=user)(|(sAMAccountName=%{Authentication:Username})(userPrincipalName=%{Authentication:Username})))
    But each produce this error on the Filter tab:
    However, if I try only this for the filter, the Filter tab works: (&(sAMAccountName=%{Authentication:Username})(objectClass=user))
    Or, if I try this filter, the Filter tab works: (&(userPrincipalName=%{Authentication:Username})(objectClass=user))
    I don't understand why if I "OR" the two using the pipe, it doesn't work?
  • 4.  RE: EAP-TLS authentication method setting - authorization required
    Posted 29 days ago
    Hi
    The syntax of this query is "a bit" confusing, at least for me. I have saved some useful syntaxes over the years and are usually using this query:
    (&(|(userPrincipalName=%{Authentication:Username}@domain.com)(sAMAccountName=%{Authentication:Username})(userPrincipalName=%{Authentication:Username}))(objectClass=user))
    With this syntax the end user can provide the username in the format both with or without the @domain.com and the sAMAccountName format.
    In the syntax above the outer parantesis is AND by the (& in the beginning and the inner is OR by the following (|. So the query is "any username in the given formats" AND of userClass=User.
    Si in your first example the & and | have changed place. In the second I can't see the error, it looks like you just moved the objectClass=user condition
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 5.  RE: EAP-TLS authentication method setting - authorization required
    MVP
    Posted 29 days ago
    Jonas, thanks for sharing your query. I tried yours, but I still get the error on the filter tab...
    Here I set your suggested filter (edited for my domain):
    Then over on the Filter tab, I still get this error:
  • 6.  RE: EAP-TLS authentication method setting - authorization required
    Posted 29 days ago
    That error you are showing is because you're attempting to run the query with the sAMAccountName set to %{Authentication:Username} rather than a valid value.
    Carson Hulcher, ACEX#110
  • 7.  RE: EAP-TLS authentication method setting - authorization required
    Posted 29 days ago
    And the query I've used for years to enable UPN.
    <Active Directory Auth Source>
    Modification to existing Authentication filter configuration to enable UPN lookup:
  • 8.  RE: EAP-TLS authentication method setting - authorization required
    MVP
    Posted 28 days ago
    Maybe I am not understanding the purpose of the Filter tab. I assumed the Filter tab was to verify/check that the filter query entered on the Configuration tab was valid, and returned valid output. Perhaps I am wrong?
    If I enter a rather simple filter query on the Configuration tab such as below:
    Then head to Attribute tab and enter a valid username, and click execute, it executes fine returning results.
    Then head to the Filter tab, and it loads fine without the error.
    (Noting at the bottom the sAMAccountName still shows as =%{Authentication:Username}, not the test username entered on Attribute tab)
    However if I try a compound query such as the query you provided, following the same steps as above, and still getting a valid response when executing a test user on the Attribute tab, then heading over to the Filter tab I still get the error message. I guess I expected the Filter tab to return either sAMAccountName OR userPrincipalName at the bottom, as that is what the query is after. But again, perhaps I am misunderstanding the usage of the Filter tab.
  • 9.  RE: EAP-TLS authentication method setting - authorization required
    Posted 28 days ago
    Apologies, wasn't looking at that closely enough.  The "Filter" tab allows you to add attributes to the filter by clicking directly into the returned data.  And correct, a compound query with multiple parameters will result in that error.
  • 10.  RE: EAP-TLS authentication method setting - authorization required
    MVP
    Posted 28 days ago
    Gotchya. Thanks for confirming, Carson. I was misunderstanding the usage of the Filter tab. Makes sense now.
    I will try your suggested query containing the "OR" statement covering both sAMAccountName and userPrincipalName - and then test to see if a user authenticating via EAP-TLS who's domain account has been disabled will in fact be denied authentication.
  • 11.  RE: EAP-TLS authentication method setting - authorization required
    Posted 28 days ago
    With EAP-TLS you have to separately check if the user account has been disabled since the authentication is just a certificate validation and account lookup.  Or you have to revoke the certificate and have that check working properly.
    Add the following filter to the AD auth source, then you can either assign a role (my preference) or check directly in enforcement.
    New filter "Custom-DisabledAccountCheck-User" to check if user account is disabled.
    sAMAccountName will "Exist" if the account is disabled.
    (&(&(userAccountControl:1.2.840.113556.1.4.803:=2)(samAccountType=805306368))(|(&(sAMAccountName=%{Authentication:Username})(objectClass=user))(&(userPrincipalName=%{Authentication:Username})(objectClass=user))))
    - sAMAccountName: DisabledAccount-User, String
    Also useful depending on your setup:
    New filter "Custom-DisabledAccountCheck-Endpoint" to check if user account is disabled.
    (&(&(userAccountControl:1.2.840.113556.1.4.803:=2)(samAccountType=805306368))(|(&(sAMAccountName=%{Endpoint:Username})(objectClass=user))(&(userPrincipalName=%{Endpoint:Username})(objectClass=user))))
    - sAMAccountName: DisabledAccount-Endpoint, String
    New filter "Custom-DisabledAccountCheck-Computer" to check if computer account is disabled.
    (&(userAccountControl:1.2.840.113556.1.4.803:=2)(objectCategory=Computer)(sAMAccountName=%{Authentication:Username})(objectClass=user))
    - sAMAccountName: DisabledAccount-Computer, String
  • 12.  RE: EAP-TLS authentication method setting - authorization required
    MVP
    Posted 28 days ago
    That circles me back around to my original question. If you are saying I have to check separately if the user account has been disabled, then I am still misunderstanding what the "Authorization Required" checkbox is doing within the EAP-TLS method setup. Could you explain more what this option is doing? The link Ariyap provided was not helpful in answering this for me. I was under the impression that with that checkbox, it was checking if the account was disabled or not - but again I may be wrong here.
    I do have my OCSP responder set up and working properly, in addition to ClearPass pointing to CRL as fallback.
    My end goal is that if a computer attempts to authenticate that has a valid/non-revoked certificate BUT the user account in AD has been disabled, to reject the authentication request.
    Thanks again Carson, I appreciate your help.
  • 13.  RE: EAP-TLS authentication method setting - authorization required
    Posted 28 days ago
    When using EAP-TLS, the "authentication" is just the certificate validation.  Example: client supplies a certificate, ClearPass checks validity, if everything is good and trusted then authentication is "yes".  The authorization required check requires that the username provided in the authentication matches an account in whatever authentication source is specified in the service.  Example: client supplies a certificate, ClearPass checks validity as good, ClearPass looks up the account in Active Directory and finds a match, then the authentication is "yes".
    The queries that I provided above will provide additional filters that you can use in authorization (remember, authentication doesn't care about anything other than certificate validity and maybe account existence) to determine if the session should be allowed.
  • 14.  RE: EAP-TLS authentication method setting - authorization required
    MVP
    Posted 28 days ago
    That's a much clearer explanation of that checkbox; thank you! So the "authorization required" checkbox is merely verifying that the presented username is found within the specified authentication source - and its not checking whether its enable or disabled - just that it exists.
    I will play with the new queries and build some checks into my enforcement policy to reject access if the AD account is found to be disabled.
