Eduroam with Clearpass
This thread has been viewed 24 times
  • 1.  Eduroam with Clearpass
    Posted 24 days ago
    Hello Everyone,
    I just want to ask if anyone of you already setup a Eduroam with Clearpass ? it seems that there is no valid documentation for clearpass integration . I just read the documentation from Giant https://archive.geant.org/projects/gn3/geant/services/cbp/Documents/cbp-79_guide_to_configuring_eduroam_using_the_aruba_wireless_controller_and_clearpass.pdf but it seems not updated. if anyone already implement it and you have a step by step guide , may I ask for your guidance. as of now im having trouble in communicating between the FLR server still figuring out why it wont able to reach the FLR (Federal Level Radius server )server and it gives me a radius authentication failed error.
  • 2.  RE: Eduroam with Clearpass
    MVP
    Posted 23 days ago
    Where are you located? We are in the US. Last July, we moved our users from a PEAP-MSCHAPv2 SSID to eduroam & TLS. We use ClearPass & AOS 8 wireless, but we use a third-party cloud provider for personal device onboarding & EAP-TLS certificate PKI.
    We started with CPPM 6.9.x and are moving to 6.12.x. We currently use AD for authorization but will be moving to Entra ID. Have you joined the Eduroam Admins mailing list?
    If you send me a PM we can exchange email addresses & we can likely help you through the details as best we know.
    Bruce Osborne ACCP ACMP
    Liberty University
    The views expressed here are my personal views and not those of my employer
  • 3.  RE: Eduroam with Clearpass
    Posted 8 hours ago
    Here is my concern also :
    1. Is clearpass local database supported by eduroam as identity store or do I need an microsoft AD, LDAP Server etc. ?
    2. Do I need to have clearpass both end from the school FLR so the server will communicate properly ?
  • 4.  RE: Eduroam with Clearpass
    Posted 9 days ago
    I know there are many customers using ClearPass for eduroam (or govroam, or publicroam which are similar mechanisms). For RADIUS proxy, I would not rely too much on policy simulation. Do you see in Access Tracker the correct service matched? Do you see the same with an actual request through a wireless SSID eduroam?
    Did you register/authorized your ClearPass with the public IP (or NAT) with your federation partner/national eduroam? If the source IP or shared secret doesn't match, the FLR may just drop your incoming requests.
    Access Tracker may provide more information (Alert tab, show logs). Also, you could run a packet capture on ClearPass (via Server Manager, Collect Logs) or an upstream device to see if there is a RADIUS packet going out (and maybe coming back).
    Your authentication seems that the RADIUS service does not respond, which may be service classification, RADIUS shared secrets, firewall, routing, etc.
    Working with your Aruba partner or Aruba TAC may be useful as well, to step by step find where in the process the issue may be and from there troubleshoot more specifically. Eduroam proxy is quite common and should just work if you 'follow the rules' (in ClearPass, routing, firewalls, with your national provider).
  • 5.  RE: Eduroam with Clearpass
    Posted 9 days ago
    I would add to contact the Eduroam admin's list for help at eduroam-admins@internet2.edu or Eduroam's support at eduroam-support@internet2.edu
    And note that there've been some issues with the TLRs a week ago so not sure if this is related.
  • 6.  RE: Eduroam with Clearpass
    MVP EXPERT
    Posted 8 days ago
    Eduroam or Govroam works the same and you can easily use the eduroam service template to deploy in both cases.
    Note: Eduroam en Govroam works the same and is based a radius server like ClearPass and with a radius proxy to the eduroam/govroam cloud.
    Publicroam works different and don't need a private owned radius server or radiusproxy. You just entered the public radius-server and key of publicroam in your wpa2-enterprise settings.
    Marcel Koedijk | MVP Expert 2024 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
