Entra AD with Intune
This thread has been viewed 29 times
  • 1.  Entra AD with Intune
    Posted 25 days ago
    Hey Everyone,
    I set up a intune extension with EAP-TLS on a clearpass 6.11.7 cluster.
    Without any issues and working fine, but we want to remove the on-prem AD and go to Entra AD.
    Since there is integration in 6.11 I added the tenant id etc.. in the source of clearpass and tested the connection.
    Which was succesful.
    So far so good.
    Now I want to see in which group the device or user is in.
    I added the authentication source in the authorization list.
    But when I do the dot1x authentication I don't see any groups coming by.
    Also in the logs I don't see any errors.
    All the intune attributes I can perfectly see.
    What I'm doing wrong?
  • 2.  RE: Entra AD with Intune
    Posted 25 days ago
    Hi Enzoj,
    EAP-TLS with cloud identity provider is quite different than onprem.
    I never tested it myself but starting with 6.11 you should be able to use Entra as an Authorization source.
    https://www.arubanetworks.com/techdocs/ClearPass/6.11/PolicyManager/Content/CPPM_UserGuide/Auth/AuthSource_Azure.htm
    Hope this helps.
  • 3.  RE: Entra AD with Intune
    Posted 25 days ago
    Do you see any data coming in from your Entra ID (Azure AD in ClearPass 6.11) Authorization Source?
    Check my presentation from Atmosphere Brussels last year.... Entra ID needs the User Principle Name (UPN) to get authorization (including Group Membership) information. Device membership is as far as I know not yet available.
  • 4.  RE: Entra AD with Intune
    Posted 25 days ago
    After more research, I found out that it was an Intune machine certificate.
    And because you mention that we must use the UPN, it didn't return anything.
    In the release notes of 6.12 I found out that I can use device groups in Clearpass in that version.
    Issue is that this is a production environment and I don't like the vanilla versions.
    Or is 6.12.1 ok to run in production environment, someone got experiences?
  • 5.  RE: Entra AD with Intune
    MVP
    Posted 17 days ago
    We worked with an Aruba TME and are preparing to deploy 6.12.1 in production, replacing our 6.9.x cluster.We are currently waiting on some of our new network infrastructure to be ready for this. I have a greenfield configuration in a Lab 6.12.1 VM that will be our initial starting point.
    Bruce Osborne ACCP ACMP
    Liberty University
    The views expressed here are my personal views and not those of my employer
