Wired Intelligent Edge
Extreme Networks AP305C & JL659A 6300M 48SR5 CL6 PoE 4SFP56 Swch PoE issue
  • 1.  Extreme Networks AP305C & JL659A 6300M 48SR5 CL6 PoE 4SFP56 Swch PoE issue
    Posted 25 days ago
    I had an issue previously where AP305C did not connect at AT power from HP Procurve 2920
    The solution was:
    https://ewouddenbreeijen.nl/net-posts/poe-issues-aruba-switches-and-powered-device/
    no lldp config <interface(s)> dot3TlvEnable poeplus_config
    I now have same APs connected to Aruba 6300M (which is running very different OS, Aruba CX, so the commands are totally different)
    Same issue:
    MB-LG-DH-Mid#sh system led
    Brightness configuration:       soft
    System LED status:
    No  Led       Colour                        Blinking
    1   Power     Off                           No blinking
    2   Status    White                         Slow blinking
    https://extreme-networks.my.site.com/ExtrArticleDetail?an=000072411
    White, Slow-blinking: The device has a CAPWAP connection to ExtremeCloud IQ, but is operating on 802.3af power instead of 802.3at power.
    MB-LG-DH-Mid#sh system power mode
    System Power Mode:   Auto/AF
    MAX tx/rx chains:    4X4
    MAX wifi0 tx power:  20dbm
    MAX wifi1 tx power:  20dbm
    USB Port:            On
    GE                   Status
    Eth0                 UP
    The PoE info from the switch
    sw-flowerroom-6300(config)# sh running-config interface 1/1/10
    interface 1/1/10
        no shutdown
        no routing
        vlan trunk native 501
        vlan trunk allowed 21,50,100,110,120,130,140,150,300
        power-over-ethernet assigned-class 4
        exit
    sw-flowerroom-6300(config)# sh power-over-ethernet 1/1/10
    Status and Configuration Information for port 1/1/10
      Power Enable           : Yes            PD signature             : single
      PoE Port Status        : delivering     PD Type                  : Type2
      Alloc-by Configured    : usage          Alloc-by Actual          : lldp-dot3
      User Profile Priority  : N/A            Port Config Priority     : Low
      Port Priority          : low            Pre-std Detect           : Disabled
      PD Requested Class     : Class4         PSE Assigned Class       : Class4
      Fault Status           : None           User set Assigned Class  : class4
      PD Class Override      : Disabled       Power Pairs Configured   : alt-a-and-alt-b
                                              Power Pairs Applied      : alt-a-and-alt-b
    PoE Counter Information
      Over Current Cnt       : 0              MPS Absent Cnt           : 3
      Power Denied Cnt       : 0              Short Cnt                : 0
    Power Information
      PSE Voltage            :  54.48 V       PSE Reserved power       :  16.80 W
      PD Current Draw        :   0.10 A       PD Power Draw            :   5.45 W
      PD Average Power Draw  :   4.88 W       PD Peak Power Draw       :   5.45 W
    LLDP Information
      MED Override             : Disabled
      MED Priority             : Critical
      PSE TLV Configured       : dot3/med
      PSE TLV Sent Type        : dot3
      PD TLV Sent Type         : dot3
      PSE Allocated Power Value: 15.40 W
      PD Requested Power Value : 15.40 W
    Any idea how to make the two of them living in harmony?
    spgsitsupport
  • 2.  RE: Extreme Networks AP305C & JL659A 6300M 48SR5 CL6 PoE 4SFP56 Swch PoE issue
    Posted 20 days ago
    As there were no takers here
    The solution is very simple
    On interface in question use:
    power-over-ethernet allocate-by class
    spgsitsupport
