Wired Intelligent Edge
last person joined: 36 minutes ago
Firmware upgrade function in web UI for 2930M switches
  • 1.  Firmware upgrade function in web UI for 2930M switches
    Posted Apr 22, 2020 09:58 AM
    I notice that in the web UI for 2930M switches there's a discrepancy in some of the available functions, specifically the Firmware Upgrade function. We have a number of 48-port 2930Ms, JL322A - I'm also using a 24-port 2390M, JL320A, in our test lab. The 322A has the Firmware Upgrade option available under System in the web UI; the 320A doesn't. Both 322As and the 320A are running firmware version WC.16.09.0007, so I would expect that the user interface would be the same for both. Is there something I need to enable in the CLI in order to make that web function visible? I've found that firmware upgrades are very quick and easy using the web option.
  • 2.  RE: Firmware upgrade function in web UI for 2930M switches
    Posted Apr 23, 2020 03:38 AM
    Are you logged on with the same privileges (manager) on both switches?
    If you don't enforce authentication, you can be logged in as operator without seeing a login prompt. And there should be an option in the UI to sign in as manager.
    Without manager privileges, you won't see the upgrade options.
  • 3.  RE: Firmware upgrade function in web UI for 2930M switches
    Posted Apr 23, 2020 07:49 AM
    Thanks, Herman - that was the issue. When I logged in to the web UI with a manager login, the firmware upgrade option was available.
    I appreciate the help and the information/education!
  • 4.  RE: Firmware upgrade function in web UI for 2930M switches
    Posted May 15, 2024 04:02 PM
    Herman, this is my first time updating the firmware on the same model switches.  Upon uploading the new version, I see primary image version as the new version (16.11.0018) and the secondary image as the old (16.04.0008).  Do I just need to reboot the switch to the new image to complete the update?  I'm probably overthinking this.  I am also using the web UI.  Appreciate the help.
  • 5.  RE: Firmware upgrade function in web UI for 2930M switches
    Posted May 15, 2024 04:08 PM
    Yes, a reload (reboot) of the switch is needed in order to activate the new firmware. Check what the 'default boot' firmware is and that is the new version, before you reboot.
