Guest Self Registration with Cambium AP
  • 1.  Guest Self Registration with Cambium AP
    Posted 19 days ago
    Greetings
    Has anyone been able to integrate cambium AP's with clearpass for Guest Self Registration?
    Basically we have everything setup according however it appears there seems to be some issues but i have some questions to ask
    We are using the IP address of the cambium AP on the guest self registration on clearpass and not the certificate FQDN as we have not introduced the certificate
    The users can sign in with the clearpass ipaddress/guest/guestuser_3.php create a user and then login but cannot browse. We can see the user creation on manage account on clearpass and also see some audit on the audit viewer but nothing on the access tracker, so in my view this process in itself isn't communicating with the AP
    We have everything setup properly in the cambium albeit we are not sure if we have the correct Postback URL of the cambium AP
    What is the proper way for guest users to access the captive portal
    1. Should it be the FQDN of the clearpass server /guest/guestuser_3.php
    Or
    2. Should it be the FQDN of the WLC /guest/guestuser_3.php
    If we use step one we can access the captive portal
    If we use step two we get a .404 error resource not found - Do we need to deactivate the securelogin.aruba.com
    We tested the above using IP while we wait to get the ssl certificate
    Please note that guestuser_3 is the guest self registration created on clearpass
  • 2.  RE: Guest Self Registration with Cambium AP
    Posted 19 days ago
    http://{$extra_fields.ga_srvr}:880/cgi-bin/hotspot_login.cgi
    You have to use a custom setup for the captive portal for the credentials to be submitted back to the correct AP.  Make sure to populate the "Extra Fields" input with the required information.  Note, the screenshot was setup against a single AP.  Use the URL from above as the "Submit URL" so that the proper IP address gets used.
    ga_ssid!=
    ga_ap_mac!=
    ga_nas_id!=
    ga_srvr!=
    ga_cmac!=
    ga_Qv!=
    Carson Hulcher, ACEX#110
  • 3.  RE: Guest Self Registration with Cambium AP
    Posted 18 days ago
    Thanks Carson
    You are the boss
    We have been bundling everything under the submit url
    so the guest system could not pass the credentials to the AP
    Will test this in the morning and revert
    Just one question, what is the best way for users to access the captive portal? is it with the clearpass IP with the .php which exposes the name/ip of the clearpass server or with the fqdn of the cambium ap
  • 4.  RE: Guest Self Registration with Cambium AP
    Posted 18 days ago
    I've not set that particular integration up in years but from what I remember you set the captive portal target in the AP configuration and you should definitely be using an FQDN for the redirect so that the interaction with ClearPass can be accomplished over HTTPS.
