Developer
HA between active/standby controllers
  • 1.  HA between active/standby controllers
    Posted Oct 25, 2023 03:36 PM
    Hi, i need your expert advice regarding High Availability in Aruba Controllers. We are currently implementing VRRP between 2 controllers (active/standby) through switch. Is it recommended to connect aruba controllers directly also using ethernet/fiber cable to acheive better high availability. I shall be looking forward to your reposnse. Thanks.
  • 2.  RE: HA between active/standby controllers
    Posted Oct 30, 2023 10:25 AM
    no, don't connect them directly, that would not increase availability. Only connect the WLC to switches and then place them in the same VLAN, so they can form the VRRP
    Bjarne
