Help 802.1x activation on HP Comware 7 switch with clearpass... ??
This thread has been viewed 52 times
  • 1.  Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted Apr 25, 2024 03:13 AM
    we trying to configure the 802.1x activation on the HP Comware 7 switch with Clearpass 6.12.1 the Switch configuration is:
    Switch Comware 7:
    port-security enable
    port-security mac-move permit
    dot1x authentication-method eap
    mac-authentication domain clearpass.radius.tacacs
    radius scheme Clearpass.radius
    primary authentication xxx.xxx.xxx.xxx key simple xxxxxx
    primary accounting xxx.xxx.xxx.xxx key simple xxxxxx
    user-name-format without-domain
    accounting-on enable
     authentication login hwtacacs-scheme tacacs local
     authorization login hwtacacs-scheme tacacs local
     accounting login hwtacacs-scheme tacacs local
     authorization command hwtacacs-scheme tacacs local
     accounting command hwtacacs-scheme tacacs
     authentication lan-access radius-scheme clearpass.radius local
     authorization lan-access radius-scheme clearpass.radius local
     accounting lan-access radius-scheme clearpass.radius local
    domain default enable clearpass.radius.tacacs
    Example for the interface:
    interface GigabitEthernet1/0/5
     port link-type hybrid
     port hybrid vlan 1 untagged
     mac-vlan enable
     stp edged-port
     stp tc-restriction
     lldp admin-status disable
     poe enable
     undo dot1x handshake
     undo dot1x multicast-trigger
     mac-authentication max-user 6
     mac-authentication host-mode multi-vlan
     port-security port-mode userlogin-secure-or-mac-ext
     we have some problems :
    1- Clearpass  can't Bounce Switch Port doesn't work with Comware 7 it gives an error:
    No response from network device
    2- MAC addresses appear on incorrect ports
    3- Clearpass doesn't receive  requests from the switch when I deb the log I see only this error:
    Dropped received EAP packet: The packet's Vlan isn't allowed in the port.
    do we miss something in the Comware 7 switch ???
    Thank you
  • 2.  RE: Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted Apr 26, 2024 07:27 AM
    Hi, MohammadH
    This is my config for Commware.
    For interfaces:
     mac-vlan enable
     stp edged-port
     poe enable
     dot1x max-user 4
     dot1x after-mac-auth max-attempt 1
     mac-authentication max-user 4
     port-security max-mac-count 4
     dhcp snooping binding record
    Radius Scheme:
     primary authentication x.x.x.x
     primary accounting x.x.x.x
     key authentication cipher xx
     key accounting cipher xx
     nas-ip interface LoopBack0
    For Bounce Switch Port:
    radius dynamic-author server
    client ip x.x.x.x key simple xxxxxx
    quit
    General config:
    dhcp snooping enable
    dhcp snooping client-detect
     dot1x quiet-period
     dot1x retry 3
     dot1x timer quiet-period 30
     dot1x timer handshake-period 30
     dot1x access-user log enable abnormal-logoff failed-login normal-logoff successful-login
     mac-authentication domain xxxxx
     mac-authentication user-name-format mac-address with-hyphen uppercase   ###---> for MAC addresses appear on incorrect ports####
     port-security access-user log enable failed-authorization mac-learning violation vlan-mac-limit
    Also, vendor for Commware is: H3C
  • 3.  RE: Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted Apr 28, 2024 03:32 AM
    Hello FF96,
    Thank you for sharing i will test it this week, I forgot to mention we have IP Phone to connect to PC
     I have a question about some commands:
    about DHCP snooping  I only need it if the DHCP is enabled in the switch correct?
    can you explain dot1x how works or for what you use it?
    • dot1x quiet-period
    • dot1x retry 3
    • dot1x timer quiet-period 30
    • dot1x timer handshake-period 30
    For interfaces do I need this command?
    • dot1x max-user 6 // What is the default ?
    • dot1x after mac-auth max-attempt 1 // this after mac-auth success the switch will try  dot1x again correct ?
    • port-security max-mac-count 4  //When will we use it ??
    • dhcp snooping binding record //  what is do exactly ?
    Thank you
  • 4.  RE: Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted 29 days ago
    All related explanations you can find in the user manual - https://networkingsupport.hpe.com/
    "For interfaces do I need this command?"
    Depends on how you set up your infrastructure
    Best Regards.
  • 5.  RE: Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted 22 days ago
    The problem with MAC addresses appearing on incorrect ports still occurring after i use the
    any another way to fix it ??
    Thank you
  • 6.  RE: Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted 21 days ago
    Hi Mohammad.
    Did you select vendor as H3C in device definition as @FF96 was mentioned?
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 7.  RE: Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted 21 days ago
    yes, I select vendor as H3C in device
  • 8.  RE: Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted 4 hours ago
    We still face the problem of MAC addresses appearing on incorrect ports when in the Switch 5130 and the Access tracker in ClearPass this happens when the  Authentication Method is MAC-Auth, with 802.1x  I see the correct port.
    Example:
    every new request comes from a different port for same PC
     is there a way to fix this ??
    Thank you
  • 9.  RE: Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted 2 hours ago
    That NAS Port is something sent from the switch. You may have a look in Access Tracker, Input tab, to see if there is maybe another field that has a better port description.
    I have not seen this before (but didn't do too much with Comware either), so you may reach out to Aruba TAC to see if they know this and know a solution.
  • 10.  RE: Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted an hour ago
    You will see the human readable port number for comware switch in the field NAS-Port-Id. Here is example from access tracker.
    Gorazd Kikelj
    MVP Guru 2024
  • 11.  RE: Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted an hour ago
    In my example, if you convert NAS-Port from decimal to Octal, you will get 100 020 001.
    1 - Slot 1
    00 - Subslot 0
    02 - Port 2
    0 001 - Vlan 1
    Gorazd Kikelj
    MVP Guru 2024
  • 12.  RE: Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted an hour ago
    Hello @Herman Robers & GorazdKikelj
    yes, I can see the better port description under the Input tab:
    but the main problem we face is the requests for the same PC come from different ports, I can read the port under the Input tab: every time a different port.
    Thank you
  • 13.  RE: Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted an hour ago
    Hi Mohhamad.
    This looks like Comware FW issue. Can you upgrade Comware to latest version?
    On 5140 I see always the same port id.
    Gorazd Kikelj
    MVP Guru 2024
  • 14.  RE: Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted an hour ago
    Hello GorazdKikelj,
    I already upgraded the switch 5130 Comware 7 to 7.1.070, Release 3507P18, which version do you use ??
    Thank you
  • 15.  RE: Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted an hour ago
    I have 5140 switch on version
    [HPE5140]displ version
    HPE Comware Software, Version 7.1.070, Release 6343P09
    This can be also the problem with this model as it is EOS for some time now.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 16.  RE: Help 802.1x activation on HP Comware 7 switch with clearpass... ??
    Posted 43 minutes ago
    the last update was Released on Feb 22, 2024, for 5130, is there a way to check if the switch has support with TAC or not ??
    I will test it with the old version in another location and see if the same problem happens or not.
    Thank you
