Help - AOS-Switch - MacAuth failing to assign VOIP vlan
  • 1.  Help - AOS-Switch - MacAuth failing to assign VOIP vlan
    Posted 25 days ago
     Hello guys,
    i'm having issues with macAuth on a Aruba 2930F (WC.16.11.0016) where the switch fails to assign a VOIP vlan. ClearPass Access tracker shows that the host is using the correct service policy and the enforcement profile is assigning the correct vlan but the VLAN is not assigned on the switch side.
    I searched all the docs but I can't find solutions. Thank you for your help.
    I get those errors on the log of the switch :
    Policy Enforcement on ClearPass
    Olivier
    Attachment(s)
    txt
    TSHOOT.txt   9 KB 1 version
  • 2.  RE: Help - AOS-Switch - MacAuth failing to assign VOIP vlan
    Posted 25 days ago
    Not sure where you got that VLAN enforcement profile from, but the VLAN ID should be in the Tunnel-Private-Group-Id attribute, not in the Egress-VLANID:
    For ArubaOS-Switch, you can also return the VLAN as Hewlett-Packard-Enterprise attibute:
    Or the HPE-Egress-VLAN-ID if you prefer to return a VLAN number instead of using Named VLANs.
    Seems you mixed up the methods, which doesn't work.
  • 3.  RE: Help - AOS-Switch - MacAuth failing to assign VOIP vlan
    Posted 24 days ago
    Hello Herman,
    Thanks for your quick answer. I'll try to set the attribute Tunnel-Private-Group-Id in my policy and test it again monday.
    Regards
