Code 401 means Unauthorized. There probably is an issue with your API credentials (wrong user/password/token) or authorization (not enough rights in the API).
It's hard to provide more detailed guidance with this limited information and it may be useful to get someone from your partner or Aruba support to have a look together and do interactive troubleshooting.
Original Message:
Sent: Mar 14, 2024 01:22 AM
Subject: Help-Clearpass OnGuard VPN(Posture) with Fortinet Fortigate
I have referring to the community article
OnGuard VPN(Posture) -FortiGate Firewall Integration | Security (arubanetworks.com)
follow the whatever setting in the article, however, it is not working, From Fortigate firewall debug log it is show 401 error code when receive api from CPPM
need the expertise from this community to help on it
thanks
