Cloud Managed Networks
High cpu usage 6000 cx switch
This thread has been viewed 70 times
  • 1.  High cpu usage 6000 cx switch
    Posted Oct 12, 2022 07:59 AM
    Hey everybody.
    I installed a new 6000 cx switch 52 port at a customer.
    I installed a sfp transceiver J4859D (which is unsupported) in one of the sfp ports.
    The switch is uplinked via fibre and the sfp.
    The switch is also acting as a core switch for other switches in the same building.
    Everything is working excellent.
    The issue is that I enabled all kinds of warnings and alarms in Aruba Central, and I get high CPU warning many times a day.
    I can not figure out what is causing the high cpu warning.
    Anybody have experience with high cpu on switches and figuring out what is causing that?
  • 2.  RE: High cpu usage 6000 cx switch
    Posted Oct 12, 2022 05:35 PM
    what version of firmware are you running on the CX6000 switch?
  • 3.  RE: High cpu usage 6000 cx switch
    Posted Oct 13, 2022 03:48 AM
    The firmware is 10.10.1000
  • 4.  RE: High cpu usage 6000 cx switch
    Posted Oct 13, 2022 04:08 AM
    check the release notes for firmware version 10.10.1010, perhaps it'll address it.
    You can also try these command on the switch to see what is causing it
    • top cpu
    • show system
    • show system resource-utilization
  • 5.  RE: High cpu usage 6000 cx switch
    Posted Dec 27, 2022 05:15 PM
    hello,
    I am facing the same issue.
    Did you get any solution?
  • 6.  RE: High cpu usage 6000 cx switch
    Posted Dec 27, 2022 06:03 PM
    with CX switches, please ensure you are running the latest maintenance release.
    for 10.10.x it is 10.10.1030
    the release notes mentions that the high CPU spike is resolved.
    https://www.arubanetworks.com/techdocs/AOS-CX/10.10/RN/rn_6000-6100_10-10-1030.pdf
  • 7.  RE: High cpu usage 6000 cx switch
    Posted Dec 28, 2022 01:59 AM
    Yes, I already tried this version.
    I have now updated to the latest version 10.11.0001
    And the problem continues.
  • 8.  RE: High cpu usage 6000 cx switch
    Posted Dec 28, 2022 02:04 AM
    please contact Aruba Support for it then.
  • 9.  RE: High cpu usage 6000 cx switch
    Posted Dec 28, 2022 07:50 AM
    Release notes say:  Workaround: The spike is generally short-lived and can be ignored.
  • 10.  RE: High cpu usage 6000 cx switch
    Posted Apr 30, 2024 10:50 AM
    we have the same issue here with 3 Aruba 6100 on the last firmware 10.12.0006.
    We have open a support ticket on aruba support, try they recommandations with spanning tree, loop protect... without significatives improvement.
    You find a solution on our side ?
    Thank you.
  • 11.  RE: High cpu usage 6000 cx switch
    Thank you.
  • 12.  RE: High cpu usage 6000 cx switch
    Posted 26 days ago
    I had similar problem earlier with 6100 and 10.12 combination but after 10.13.1000 I haven't suffered such problems any more.
    (If I recall right I think I got high CPU problems only with switches manufactured in 2020-2021)
    Jori Luoto
    AV-IT Specialist
  • 13.  RE: High cpu usage 6000 cx switch
    MVP EXPERT
    Posted 26 days ago
    same here on different customer
    • safely ignore it
    • aruba please fix
    Marcel Koedijk | MVP Expert 2024 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
