Well that is what is reported in Central when we experience this issue on our 615s. We have over 350 APs deployed.
We haven't experienced many instances since moving to 10.5/10.6 and collapsing our building based clusters to large singular campus groups
But it is an chain effect situation. All it takes is one AP to cause a gradual cascading effect through an entire cluster. A reboot of each AP will clear it until the next one
![Logo Description automatically generated](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/e34a33156e4b429cbe028741b749f865.jpg) ![An orange slice with a white background Description automatically generated with low confidence](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/2f78158eecf44e399bef7ac758c7c91e.jpg) | Mr. Scott McCambley Manager of Network, Server & Cloud Infrastructure P.O. Box 3013 - 2 Ridley Road St. Catharines, Ontario L2R 7C3 905-684-1889 x2218 ridleycollege.com ![signature_2362232615](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/f52fff73c4444a09bffc58dac8eea830.jpg) |
If you require technical support, simply click the button below to submit a ticket.
![signature_1103703789](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/2def34dbef9a46479e71e93b0e629b4a.png)
Original Message:
Sent: 5/8/2024 9:55:00 AM
Subject: RE: How can I get alerted on Access Point with red light?
Red LED for the system status indicates a general system error condition - not necessarily because of or exclusive to CPU usage. Data from the AP would be needed to confirm.
Original Message:
Sent: May 08, 2024 09:48 AM
Subject: How can I get alerted on Access Point with red light?
Red Light is due to maxed cpu usage
Original Message:
Sent: May 07, 2024 09:43 PM
Have you any information as to why the AP is going into an error state? Opened a TAC case to resolve whatever error is occurring or replace the hardware if necessary?
Carson Hulcher, ACEX#110
Original Message:
Sent: May 07, 2024 02:11 PM
Occasionally our 515 or 505 WAPs will go into a problem state displaying a red LED light. In this state, clients cannot connect to them, but the on-prem Controller (7205 running 8.12.0.0) does not report them as "down". This has been the case on both the current OS and previous 8.10 and 8.7 OS.
Does anyone know if there is a way to get alerted (via email) by the controller or SNMP if a WAP goes red-light like this?
We do have SNMP monitoring in place, but it (like the controller) is currently only looking at up/down status.
Demetri
