Hi Pavan,
Thank for your response currently, the reports tab don't work correctly
![Screenshot 2019-07-24 at 22.23.33.png Screenshot 2019-07-24 at 22.23.33.png](https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedInlineFiles/f125ee8dabd844ae9e7aa8e0ce455800_28a09ca09dc64014baee356af9735724)
But is not exactly what I want, I would like to generate a heatmap directly with my mobile application using the meridian SDK for iOS and on the generated heatmap I would like only records movement of the current user.
How I can use the meridian SDK to do this? If it is not possible directly what are alternatives?
Thanks in advance
