How to check if ClearPass joined a domain
This thread has been viewed 24 times
  • 1.  How to check if ClearPass joined a domain
    Posted May 31, 2018 06:46 PM
    Hi gurus,
    I wonder if there is anyway to check if ClearPass joined a domain correctly, without leaving and joining the domain again. This is my situation, Event Viewer shows a problem with the domain:
    But I can see ClearPass is joined to the domain:
    But I don't know if the information of the last screenshot is only when ClearPass joined the domain the first time and not currently. How can I check it without leaving the domain?
    Thanks in advance,
    Julián
  • 2.  RE: How to check if ClearPass joined a domain
    Posted May 31, 2018 09:06 PM
    Looks like you are having issues with the domain process
    You are running a very old code and it is no longer supported by Aruba , you should consider upgrading to the latest 6.7.x
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: How to check if ClearPass joined a domain
    Posted May 31, 2018 11:12 PM
    Hi Victor,
    Ok, and thanks for the advice about the code, I didn't know is no longer supported.
    Julián
  • 4.  RE: How to check if ClearPass joined a domain
    Posted Jun 01, 2018 03:20 AM
    +1 on the ClearPass version. Make sure you are running up to date ClearPass software.
    On the domain join check, you can do that on the CLI with the ad testjoin command:
    [appadmin@cppm-nl]# ad testjoin NL
    Join is OK
    Where NL is the NETBIOS name of my domain.
  • 5.  RE: How to check if ClearPass joined a domain
    Posted Jun 01, 2018 11:54 AM
    Hi Herman,
    That's exactly what I was looking for, many thanks!
    Julián
  • 6.  RE: How to check if ClearPass joined a domain
    MVP EXPERT
    Posted May 22, 2024 01:26 PM
    Hi Herman,
    Known its a old topic but when de ad testjoin NL failed. How i have to interpreted this issue?
    Marcel Koedijk | MVP Expert 2024 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 7.  RE: How to check if ClearPass joined a domain
    Posted May 23, 2024 03:23 AM
    Hi Marcel
    Domain joins can be a challange if the Active Directory has been hardened. In your case it looks like either the account you try to do the test with isn't correct, or the host name isn't accepted for some reason. I don't think I have seen this error message.
    If you try to join from the GUI, what message do you get?
    As the initial issue in this thread is something else, maybe a new thread would be better.
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 8.  RE: How to check if ClearPass joined a domain
    Posted 28 days ago
    I would verify there are no forbidden characters in the hostname. That could be - _ or so...
    Message suggests that the kerberos hostname is in an invalid format. Having symbols in the hostname is what I can think of.
