Network Management
how to configure trunk in two situations
  • 1.  how to configure trunk in two situations
    Posted 30 days ago
    1. trunk between 2530 to 2930
    using trk1, trk2 etc
    or with
    untag on the the default vlan and tag on the vlans
    what is the difference ?
    and also if i have on one of the switches above 2 different trunks to to different switch's,
    i need to user the trk1, trk2 etc or again only untag on the defualt and tag the vlans i want to pass ?
    2. trunk between 2930 to 6000/8320
    in this situation only the 2930 have a trk1, trk2 etc,
    the 6000/8320 don't have this trk1, trk2,
    i can only see i can create lag or make the port nativ untag and allowed the vlans
    so which way is the right one.
    thanks,
    liran
  • 2.  RE: how to configure trunk in two situations
    Posted 30 days ago
    Well you are configuring two separate protocols in this case - and the terminology/syntax between aos-s (2930) and aos-cx (6000) is different for each.
    So if the goal is to configure redundant Layer-2 Links between two switches:
    You will want first want to configure link aggregation - two physical interfaces grouped together
    AOS-S = trunk 1-2 trk1 lacp  - This would initial a trunk using 802.3ad dynamic standard on Switch Ports 1 and 2
    AOS-CX = interface lag 1 ~ lacp mode active & interface 1/1/1 ~ lag 100 interface 1/1/2 ~ lag 100
    Then you can VLANs to those link aggs - for multiple VLANS
    AOS-S = interface Trk1 ~ untagged vlan 1 ~ tagged vlan 1,11,21
    AOS-CX = interface lag 1 ~ vlan trunk native 1 ~ vlan trunk allowed 1,11,21
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
