Location Services
last person joined: 12 days ago
Location-based mobile app development and Bluetooth-based asset tracking with Meridian. Gathering analytics and business intelligence from Wi-Fi with Analytics and Location Engine (ALE).
How to connect controller Os 8.3 to ALE
  • 1.  How to connect controller Os 8.3 to ALE
    Posted Apr 25, 2019 11:47 PM
    Hi Everyone,
    Am using controller aruba 7005 Os 8.3 but can not find folder connect to analytics and Location Engine (ALE).
    Can you help me check?
    Thank you.
  • 2.  RE: How to connect controller Os 8.3 to ALE
  • 3.  RE: How to connect controller Os 8.3 to ALE
    Posted May 20, 2019 10:10 PM
    Hi Pavan,
    I follow link but config ssh erro , can you help me check?
    (attach file)
    https://www.arubanetworks.com/techdocs/ArubaOS_83x_Web_Help/Content/PDFs/ArubaOS%208.3.0.x%20CLI%20Reference%20Guide.pdf
    and Check page 151
  • 4.  RE: How to connect controller Os 8.3 to ALE
    Posted May 20, 2019 10:19 PM
    Dear Pavan,
    My controller: ArubaOS (MODEL: Aruba7005), Version 8.3.0.6. But when config ALE as your guide, it said:
    (Aruba7005) [mynode] (config) #ale-configuration
    Command not applicable for this platform
    How can I fix this? Thank you very much.
  • 5.  RE: How to connect controller Os 8.3 to ALE
    Posted May 21, 2019 07:14 AM
    Are you running on MD or its a standalone controller? I am able to run on my MM.
    (DK-MM) [mynode] (config) #ale-configuration
    (DK-MM) ^[mynode] (config-submode)#
  • 6.  RE: How to connect controller Os 8.3 to ALE
    Posted Sep 26, 2019 08:17 AM
    Did you get it solved ? Because I'm facing the same issue on my standalone controller (aos 8.5).
    I'm afraid it is not possible to make ale configuration on a aos 8.x standalone controller ...
    Can somebody confirm if we definitively need Mobility Master setup in order to configure ale ?
  • 7.  RE: How to connect controller Os 8.3 to ALE
    Posted Sep 26, 2019 08:50 AM
    Are you able to run below command from AOS CLI
    #show ale-configuration
    There is no such limation, it should work for standalone aswell.
  • 8.  RE: How to connect controller Os 8.3 to ALE
    Posted Apr 02, 2020 05:11 PM
    I checked it in House. Looks like the standalone is not giving the ALE tab. Only when we check from MM it is.
    I am checking with the controller guys on this. I will update the thread based on their response.
  • 9.  RE: How to connect controller Os 8.3 to ALE
    Posted Apr 26, 2019 09:22 AM
    For GUI,
    The below Airheads post might be helpful.
    https://community.arubanetworks.com/t5/Forum-Fran%C3%A7ais/ALE-amp-AOS8-Notes-d-int%C3%A9gration/td-p/304619
  • 10.  RE: How to connect controller Os 8.3 to ALE
    Posted Apr 27, 2019 12:09 AM
    Hi Pavan,
    I don't see button ALE? pls check image
  • 11.  RE: How to connect controller Os 8.3 to ALE
    Posted Apr 27, 2019 08:10 AM
    Please choose Mobility Master folder (Top folder) and then select More. You will than be able to see ALE option.
  • 12.  RE: How to connect controller Os 8.3 to ALE
    Posted May 03, 2019 02:22 AM
    Hi Pavan,
    Now I creat ssid using captive portal but can't access internet, you can help me check how to add roles from captive portal?
    Thank you so much.
  • 13.  RE: How to connect controller Os 8.3 to ALE
    Posted May 03, 2019 05:44 AM
    Open new thread this thread is for location query! are you creating roles in Clearpass or controller? If you are getting internet then check ACL rules for that role.
