This is what is expected to be normal. If users don't authenticate to the captive portal, they will stick in the captive portal redirect role, because you won't know if they don't authenticate or don't have credentials to authenticate. You may do something with MAC authentication and 'reject' those clients after a certain amount of time, but then they can't authenticate once they get the credentials if they are disconnected. In general, WiFi clients will just reconnect if they get disconnected.
What would be the reason that users can't authenticate?
What would be the reason that you want to 'reduce the time'?
Original Message:
Sent: Sep 14, 2022 05:26 AM
Subject: How to drop un-authenticated user or reduce their connection time?
I have Guest SSID that authenticate users with Captive portal.
however, when user can't authenticate, it seems to get IP address and show up connected to CPPM-Prof
how can I reduce the time of the users that cannot authneticate?
