Wired Intelligent Edge
How to get actual power consumption on HP5412 Switches ( J9851A)
  • 1.  How to get actual power consumption on HP5412 Switches ( J9851A)
    Posted Jul 22, 2022 09:52 AM
    Good afternoon,
    one of our custiomers wants to find out how much power (Watts) his switches are currently needing. The idea is to check the power consumtion against the USVs to get the time the USVs are able to deal when the normal power fails.
    The command "show system power supply" just gives me the power of the installed power supplies which is the maximum power consumption.
    I can query each port to see how much PoE power is currently used.
    Do you know a command or way how to check how much power the switch is currently using for PoE,  management module, interface cards together ?
    Many thanks for your help !
    Markus
