That is not a SD-WAN question, not even an Aruba questions. Would be better to ask in an HPE Community.
But, the documentation for the 1920 is here, and it does not mention the option to change the SSH port. Just enable/disable is supported. Hope that is good enough as you won't find documentation on features that are not available in general.
Original Message:
Sent: Aug 10, 2023 04:08 AM
Subject: How to HPE Switch V1920, V1910 SSH Port change ?
Hello, I'm curious about changing the SSH port on HPE switches. The switch models I'm using are V1920 and V1910, and I would like to know how to change the SSH port. If these models do not support changing the SSH port, I would need documentation related to that. Please provide information about the method for changing the port or where to find the appropriate documentation.
