I do have a Aruba Virtual Conductor (8.10.0.12 LSR), two 9004 Controller and two 9240 Controller.
I want to monitor the number/count of connected APs and Clients from the Conductor via SNMP. Is it possible and if, then how? The GUI displays the information, but I dont get it by SNMP.
I tried the aruba-wlan,my and several others, but still no result. For Example (result as zero...):
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/55ce006e04ac4cbf850e47bff1ae9a63.png)
GUI:
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/a8cae644df214e77ba72ff902fda70bf.png)
optionally: If it is possible it would be nice to monitor all the connected Access Points , maybe there is a table for that?
Edit:
CLI provides following information:
But how can I access these information via SNMP?
I don't want to monitor the 4 Controllers as I want to monitor the sum of all APs and users over all both Controller Clusters.
Thanks and kind regards
Robert
Edit:
Rest API Call would also be okay. I tried with a API showcommand, but I do not know how to filter it or how to get single value from that...
Does not work with '...' like in the example:
C:\_IT>curl -b "aruba-cookie" -X GET -i --header "X-CSRF-Token:MzNhODJhYzYtZTQzNi00NDE2LThlMDctZTgw" '"https://v-it142.ewr.local:4343/v1/configuration/showcommand?command=show+ap+database-summary"&filter=[ { "AP Database Summary" : { "$eq" : "Total Up" } } ]'
curl: (3) URL rejected: Port number was not a decimal number between 0 and 65535
Der Befehl "filter" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
without '...' the filter error still occurs:
C:\_IT>curl -b "aruba-cookie" -X GET -i --header "X-CSRF-Token:MzNhODJhYzYtZTQzNi00NDE2LThlMDctZTgw" https://v-it142.ewr.local:4343/v1/configuration/showcommand?command=show+ap+database-summary&filter=[ { "Object" : { "$eq" : "Total Up" } } ]
or
C:\_IT>curl -b "aruba-cookie" -X GET -i --header "X-CSRF-Token:MzNhODJhYzYtZTQzNi00NDE2LThlMDctZTgw" https://v-it142.ewr.local:4343/v1/configuration/showcommand?command=show+ap+database-summary&filter=[{"AP Database Summary" : { "$eq" : "Total Up" } } ]
HTTP/1.1 200 OK
Date: Wed, 05 Jun 2024 13:18:05 GMT
Server: Apache
Expires: 0
X-Frame-Options: SAMEORIGIN
X-XSS-Protection: 1; mode=block
X-UA-Compatible: IE=edge;IE=11;IE=10;IE=9
Strict-Transport-Security: max-age=31536000
Expires: 0
Set-Cookie: SESSION=OWRhMDcyY2QtODdiNy00ZGQwLTgyY2MtNGM1; path=/; HttpOnly; SameSite=Lax;;Secure;
Content-Length: 2244
Content-Type: application/json
"AP Database Summary": [
"AP Mode": "Access Points",
"Active Up": "0",
"RAP Down": "0",
"RAP Rebooting*": "0",
"RAP Up": "0",
"RAP Upgrading*": "0",
"Standby Up": "0",
"Total Down": "1",
"Total Rebooting*": "0",
"Total Up": "96", <== I want to monitor THIS value !
"Total Upgrading*": "0"
"_meta": [
"AP Mode",
"Total Up",
"Total Down",
"Total Upgrading*",
"Total Rebooting*",
"RAP Up",
"RAP Down",
"RAP Upgrading*",
"RAP Rebooting*",
"Active Up",
"Standby Up"
}Der Befehl "filter" ist entweder falsch geschrieben oder
Edit 2:
show global-user-table count could be the solution for User count, but also here the filter does not work. I need the value only
C:\_IT>curl -b "aruba-cookie" -X GET -i --header "X-CSRF-Token:NDk4M2RjZjgtMTNlOS00OTJmLWIwOGYtODkx" https://v-it142.ewr.local:4343/v1/configuration/showcommand?command=show+global-user-table+count &filter=[{"OBJECT" : { "$eq" : "The number of global users" }}]
HTTP/1.1 200 OK
Date: Wed, 05 Jun 2024 14:39:35 GMT
Server: Apache
Expires: 0
Expires: 0
Set-Cookie: SESSION=YWNkNmI2Y2ItODlkMi00NzI3LWE4OWMtMWQ2; path=/; HttpOnly; SameSite=Lax;;Secure;
Content-Length: 59
"_data": [
"The number of global users : 150"
