how to turn 2.4 and 5GHZ radio off through cli in AOS10 environment
  • 1.  how to turn 2.4 and 5GHZ radio off through cli in AOS10 environment
    Posted 25 days ago
    we have setup our wireless environment in AOS10 Aruba Central and trying to turn off radio 0, 1, 2 . it takes the value through Aruba Central but wondering if there is specific cli command
  • 2.  RE: how to turn 2.4 and 5GHZ radio off through cli in AOS10 environment
    Posted 25 days ago
    In AOS 10, configuration should be done through Central. Even if you would be able to change things on the CLI, it will be returned back as soon as the AP is connected to Central again. What is the use-case, or what is it that you try to achieve that you can't do through Central?
