Aruba Apps
last person joined: 16 days ago
The HPE Aruba Networking Apps board is designed to address questions, comments, and feature requests for all HPE Aruba Networking mobile Apps
How to use to Freeradius += operator with ClearPass
  • 1.  How to use to Freeradius += operator with ClearPass
    Posted Sep 29, 2023 10:57 AM
    I use a LocalUsers database with users having a {user}@{group} format.
    I would like to generate Cisco-AVPair radius attributes based both on {group} and on {user}.
    I use an Enforcement policy which is setting actions based on {group}, then actions based on {user}. But i see only Attributes set by the {group} profile in the radius reply.
    And iIf a put the action based on user first, i see only the user profile attributes...
    Is there a way to have the sum of Cisco-AvPair attributes in the same radius reply (similar to the += Freeradius operator), or i am doing something wrong ?
    Philippe
  • 2.  RE: How to use to Freeradius += operator with ClearPass
    Posted Oct 04, 2023 11:20 AM
    I think if you have multiple enforcement profiles that have conflicting attributes, one will be overwritten by the other, not concatenated.
    Depending on your use-case, you may use tokenized attributes in a single enforcement profile, like putting in %{Attribute-for-User} and %{Attribute-for-Group}.
    Without knowing exactly what you try to achieve, it's hard to tell if that works or not. It may be best to get your Aruba partner or Aruba SE involved to discuss this in full detail and see what would be possible.
