AOS-CX doesnt support Device replacement workflow.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/ec790459f3794acda50ee2000fd3a09a.png)
you can copy the configuration from "Multi-Edit" windows.
- Navigate to the defective switch configuration and enable "Multi-Edit"
- select "view config", and then copy the configuration by pressing "CTRL+A" and then "CTRL+C"
- Paste the configuration into a notepad.
- apply the same configuration into new ArubaCX switch.
Harendra
ACEX165
Original Message:
Sent: Jul 10, 2024 09:34 AM
Subject: howto swap OS-CX switch in GUI mode
Hello
Scenario: I want to replace a defective OS-CX switch that is managed in GUI mode in Central by a cold spare unit.
- is it possible to download the config of the defective switch from Central so I can import it in the spare one? I notice that even if the switch is operational, I'm not able to download the config from local switch GUI eighter.
- is it possible to automatically restore the config from Central to the spare unit (I know this is possible for AOS switches via Global > Organisation > Device Replacement
Kind regards
Wouter
