Comware
HP 1920 divided into two switches
  • 1.  HP 1920 divided into two switches
    Posted Jun 27, 2024 11:08 AM
    There is an HP 1920 switch with 24 ports, and it needs to be divided into two separate virtual switches. For example, port 1-8 is vlan 1, and port 9-24 is vlan 21. Both Vlans must use the same subnet, for example 10.0.0.1/24. Gateway 10.0.0.1 is plugged into port 1, computer 10.0.0.21 is plugged into port 21. Access of computer 10.0.0.21 to gateway 10.0.0.1 should appear only if both vlan-based virtual switches are connected via port 8 - 9.
    vlan 1
    vlan 21
     description VLAN 0021 test
    interface GigabitEthernet1/0/1 - 7
     port auto-power-down
     stp edged-port enable
    interface GigabitEthernet1/0/8
     port link-type hybrid
     port hybrid vlan 1 21 tagged
    interface GigabitEthernet1/0/9
    interface GigabitEthernet1/0/10 - 24
     port access vlan 21
  • 2.  RE: HP 1920 divided into two switches
    Posted 19 days ago
    Hi
    So, you want to split a switch in 2, and have a "physical" interconnect between them ?
    Strange (1920 is capable of routing) but nevermind :
    the only way to do it is :
    • disable spanning-tree (if you need STP, you're quite dead) or any other loop protection function.
    • don't use hybrid ports for 1/0/8 and 1/0/9 : only access (untagged)
      • 1/0/8 access vlan 1
      • 1/0/9 access vlan 21
    Frederic
    (kudos welcome)
  • 3.  RE: HP 1920 divided into two switches
    Posted 13 days ago
    Hi frmeunier.
    That's what I tried to do. I managed to do it on HP 1920S. But I can't do it on 1920. It looks like there are some configuration features in the old firmware. Any ideas on what to do?
  • 4.  RE: HP 1920 divided into two switches
    Posted 12 days ago
    please give the config you "tried to do" on the 1920 switch.(as what you gave in first post is not valid)
    Are you using the webgui or CLI to manage the 1920 ?
    Frederic
    (kudos welcome)
  • 5.  RE: HP 1920 divided into two switches
    Posted 6 days ago
    Hi frmeunier.
    I use webgui, but I can try via CLI too.
    Below I attach the configuration file
     version 5.20.99, Release 1121
     sysname HPE
     domain default enable system
     ipv6
     telnet server enable
     ssl version ssl3.0 disable
     web idle-timeout 999
     password-recovery enable
    vlan 1
    vlan 21
    domain system
     access-limit disable
     state active
     idle-cut disable
     self-service-url disable
    user-group system
     group-attribute allow-guest
    local-user admin
     password cipher .....
     authorization-attribute level 3
     authorization-attribute user-profile admin
     service-type lan-access
     service-type ssh telnet terminal
     service-type ftp
     service-type web
     stp mode rstp
     stp enable
    interface NULL0
    interface Vlan-interface1
     ip address 192.168.74.254 255.255.255.0
    interface GigabitEthernet1/0/2
    interface GigabitEthernet1/0/3
    interface GigabitEthernet1/0/4
    interface GigabitEthernet1/0/5
    interface GigabitEthernet1/0/6
    interface GigabitEthernet1/0/7
     port access vlan 21
    interface GigabitEthernet1/0/11
     port access vlan 21
    interface GigabitEthernet1/0/12
     port access vlan 21
    interface GigabitEthernet1/0/13
     port access vlan 21
    interface GigabitEthernet1/0/14
     port access vlan 21
    interface GigabitEthernet1/0/15
     port access vlan 21
    interface GigabitEthernet1/0/16
     port access vlan 21
    interface GigabitEthernet1/0/17
     port access vlan 21
    interface GigabitEthernet1/0/18
     port access vlan 21
    interface GigabitEthernet1/0/19
     port access vlan 21
    interface GigabitEthernet1/0/20
     port access vlan 21
    interface GigabitEthernet1/0/21
     port access vlan 21
    interface GigabitEthernet1/0/22
     port access vlan 21
    interface GigabitEthernet1/0/23
     port access vlan 21
    interface GigabitEthernet1/0/24
     port access vlan 21
    interface GigabitEthernet1/0/25
    interface GigabitEthernet1/0/26
    interface GigabitEthernet1/0/27
    interface GigabitEthernet1/0/28
     ip route-static 0.0.0.0 0.0.0.0 192.168.74.1 preference 70
     undo info-center logfile enable
     ntp-service unicast-server 20.101.57.9
     ssh server enable
     sftp server enable
     ip https enable
     load xml-configuration
    user-interface aux 0
     authentication-mode scheme
    user-interface vty 0 15
    return
  • 6.  RE: HP 1920 divided into two switches
    Posted 5 days ago
    Hi Raul
    STP is enabled on ports 8 and 9 : you must disable it at least on these two.
    As previously advised, do not use hybrid configuration but access instead :
     port link-type access
     port access vlan 1
     undo stp enable
     port access vlan 21
     undo stp enable
    Frederic
    (kudos welcome)
