Comware
HP V1910-24G Switch Application program does not exist
  • 1.  HP V1910-24G Switch Application program does not exist
    Posted Apr 09, 2014 02:45 AM
    * HP V1910-24G Switch BOOTROM, Version 169 *
    Copyright (c) 2010-2013 Hewlett-Packard Development Company, L.P.
    Creation Date : Oct 12 2013
    CPU L1 Cache : 32KB
    CPU Clock Speed : 333MHz
    Memory Size : 128MB
    Flash Size : 128MB
    CPLD Version : 002
    PCB Version : Ver.B
    Mac Address : CC3E5F7C5213
    Application program does not exist.
    BootRom password: Not required. Please press Enter to continue.
    How to restore the device?
    P.S. This thread has been moevd from ProCurve / ProVision-Based to Web and Unmanaged. - Hp forum moderator
  • 2.  RE: HP V1910-24G Switch Application program does not exist
    Posted Apr 14, 2014 10:07 AM
    So, the solution is found. Sorry helpdesk HP has not responded to my question.
    The first thing you need to download the old firmware (new not be able to restore the system.)
    Here is the link:  https://h10145.www1.hpe.com/support/SupportLookUp.aspx
    Download the firmware: 1910_5.20.R1111P01     16-Apr-2012    26-Apr-2012    Release notes     10.3 MB
    Next, connect the switch through the console port (the manual is) settings Connection:
    Hyper Terminal settings
    Turn off the power and then conclude. The screen displays the message:
    Starting......
    * HP V1910-24G Switch BOOTROM, Version 158 *
    Copyright (c) 2010-2012 Hewlett-Packard Development Company, L.P.
    Creation Date : Jun 15 2012
    CPU L1 Cache : 32KB
    Memory Size : 128MB
    Flash Size : 128MB
    CPLD Version : 002
    PCB Version : Ver.B
    Please input BootRom password:
    Press Enter.
    BOOT MENU
    1. Download application file to flash
    2. Select application file to boot
    3. Display all files in flash
    4. Delete file from flash
    5. Modify BootRom password
    6. Enter BootRom upgrade menu <- select this
    7. Skip current system configuration
    8. Set BootRom password recovery
    9. Set switch startup mode
    0. Reboot
    Enter your choice(0-9): 6
    1. Update full BootRom <- select this
    2. Update extended BootRom
    3. Update basic BootRom
    0. Return to boot menu
    Enter your choice(0-3): 1
    1. Set TFTP protocol parameters
    2. Set FTP protocol parameters
    3. Set XMODEM protocol parameters <- select this
    Enter your choice(0-3): 3
    Please select your download baudrate:
    1. 9600
    2. 19200
    3.* 38400
    4. 57600
    5. 115200
    Enter your choice(0-5): 5
    Download baudrate is 115200 bps
    Please change the terminal's baudrate to 115200 bps and select XMODEM protocol
    Press enter key when ready
    Now please start transfer file with XMODEM protocol
    If you want to exit, Press <Ctrl+X>
    Loading ...CCCCDone!
    Wait... ~20min
    Will you Update Basic BootRom? (Y/N):Y
    Updating Basic BootRom...Done!
    Updating extended BootRom? (Y/N):Y
    Updating extended BootRom...Done!
    Please change the terminal's baudrate to 38400 bps, press ENTER when ready.
    0. Return to boot menu <- select this
    Enter your choice(0-3): 0
    BOOT MENU
    1. Download application file to flash <- select this
    0. Reboot
    Enter your choice(0-9): 1
    1. 9600
    2. 19200
    3.* 38400
    4. 57600
    5. 115200 <- select this
    Are you sure to download file to flash? Yes or No (Y/N):Y
    Loading ...CCCDone!
    Wait... ~20min
    Load File name : default_file
    The file already exists, will you overwrite it? (Y/N):Y
    Deleting........................................................................
    ..........................................Done!
    Free space: 98828288 bytes
    Writing flash...................................................................
    Please input the file attribute (Main/Backup/None) M
    The attribute of V1910-CMW520-R1513P81.bin is changed from main to none!
    Done!
    Your baudrate should be set to 38400 bps again!
    BOOT MENU
    0. Reboot <- select this
    Enter your choice(0-9): 0
    Starting......
    * HP V1910-24G Switch BOOTROM, Version 154 *
    Creation Date : Mar 19 2012
    CPU L1 Cache : 32KB
    Memory Size : 128MB
    Flash Size : 128MB
    CPLD Version : 002
    PCB Version : Ver.B
    the normal and back basic is not equal, update back basic....
    the normal and back extend is not equal, update back extend....
    Press Ctrl-B to enter Extended Boot menu...0
    Starting to get the main application file--flash:/default_file!.................
    The main application file is self-decompressing.................................
    ............Done!
    System is starting...
    Configuration file is skipped.
    User interface aux0 is available.
    Press ENTER to get started.
    <HP V1910 Switch>
    #Apr 26 12:02:14:504 2000 HP V1910 Switch SHELL/4/LOGIN:
    Trap 1.3.6.1.4.1.25506.2.2.1.1.3.0.1: login from Console
    %Apr 26 12:02:14:644 2000 HP V1910 Switch SHELL/4/LOGIN: Console login from aux0
    User view commands:
    initialize Delete the startup configuration file and reboot system
    ipsetup Specify the IP address of the VLAN interface 1
    password Specify password of local user
    ping Ping function
    quit Exit from current command view
    reboot Reboot system
    summary Display summary information of the device.
    upgrade Upgrade the system boot file or the Boot ROM program
    <HP V1910 Switch>
    ALL OK! Switch WORK!
    [Note: broken link updated by Mod]
  • 3.  RE: HP V1910-24G Switch Application program does not exist
    Posted Aug 27, 2014 02:13 PM
    Thanks for this post.
    For users who are uploading throug tftp, you have to reboot the switch after updating the extended BootRom. After that you can upload the main application file.
     p.s. i used a V1910-48G Switch.
  • 4.  RE: HP V1910-24G Switch Application program does not exist
    Posted Jul 03, 2015 05:44 AM
    for me this solution
    doesnt work.
    Starting......
    *                   3COM 2920-SFP Plus BOOTROM, Version 154                    *
    Copyright(c) 2004-2012 3Com Corp. and its licensors. All rights reserved.
    CPU L1 Cache        : 32KB
    Memory Size         : 128MB
    Flash Size          : 128MB
    CPLD Version        : 002
    PCB Version         : Ver.B
    Mac Address         : 4001C6791507
    The main application file does not exist--flash:/default_file!
    Booting App fails!
    Display all file(s) in flash:
    File Number    File Size(bytes)     File Name
    1(*)           10184064             default_file
    2              151                  system.xml
    3(*)           2101                 startup.cfg
    Free space: 47620096 bytes
    No right Application file in the current device!
    there is something else to try?
    thank you
  • 5.  RE: HP V1910-24G Switch Application program does not exist
    Posted Feb 28, 2018 10:48 AM
    Same for me. Does not work. It is not possible to find such old firmware, as I have slightly another model: JG538A. Old ones are just not recognised as firmware - I do not have an option to upgrade this or that: simply after downloading the old one I am faiiling back to meny of Configure Serial Port, etc. It just does not asking am I up to update basic and then extended firmware. If I upload a modern one - it does ask, but... freezing on "validating firmware". (Note: the modern one is really for exactly JG538A). Any ideas?
  • 6.  RE: HP V1910-24G Switch Application program does not exist
    Posted Aug 03, 2018 06:03 AM
    Unfortunatly the link to the download appears to be broken. I have a switch with this problem and replacing it is not an option. Help!
  • 7.  RE: HP V1910-24G Switch Application program does not exist
    Posted Dec 07, 2019 03:14 AM
    It appears there maybe a couple of solutions to this.
    I found there appears to be 2 types of firmware releases for these procurve switches
    For instance formware JG538A_5.20.R1120 was released in March 2019, this does not seem to include the boot rom component.
    In April the alternative firmware stream was released as 1910_5.20.R1519P06. this does appear to include the boot rom component of the firmware..
    The 1910_5.20.R1519P06 release covers all 1910 varients including POE.. (but please confirm this your self)
    Therefore when I flashed the firmware of my 1910-48g from JG540A-CMW520-R1102 to 1910_5.20.R1519P06 it worked fine.
    Where as when I tried to flash the firmware of my 1910-48g from JG540A-CMW520-R1102 to 1910_5.20.R1120 it confinued to fail with an error related to "could not load next boot environment".
    Here's the current URL to version 1519P06
    https://h10145.www1.hpe.com/downloads/SoftwareReleases.aspx?ProductNumber=JE006A
  • 8.  RE: HP V1910-24G Switch Application program does not exist
    Posted Jul 16, 2024 12:40 PM
    how do you get the default_file ???
  • 9.  RE: HP V1910-24G Switch Application program does not exist
    Posted Jul 15, 2021 03:19 PM
    Hello, how are you? I have the same problem, you could solve it
