Comware
HPE 5510 Switch - .bin files missing
  • 1.  HPE 5510 Switch - .bin files missing
    Posted 2 days ago
    I've been trying to upgrade my HPE 5510 HI from the stock FW to the latest, I upgrade from 1118 to 1120 and it failed, I then rebooted the switch and now everytim I try to restart, factory reset upgrade, it errors.
    I checked the CLI DIR command and see the standard files from the manual and noticed it has .bin files.  However my config does switch does not have these files:
    Directory of flash:
       0 -rw-        6340 Jun 26 2024 14:35:20   HP5510_172_16_33_26.cfg
       1 -rw-      107869 Jun 26 2024 14:35:20   HP5510_172_16_33_26.mdb
       2 drw-           - May 23 2016 18:38:55   diagfile
       3 -rw-         735 Jan 14 2013 19:14:04   hostkey
       4 -rw-         835 Jun 26 2024 14:35:20   ifindex.dat
       5 -rw-           0 May 23 2016 12:00:22   lauth.dat
       6 drw-           - Jan 01 2013 00:00:37   license
       7 drw-           - Jan 02 2013 00:00:21   logfile
       8 drw-           - Jan 01 2013 05:25:05   pki
       9 drw-           - Jan 01 2013 00:00:30   seclog
      10 -rw-         591 Jan 14 2013 19:14:04   serverkey
      11 -rw-        6231 Jan 17 2024 15:46:56   startup.cfg
      12 -rw-      101999 Jan 17 2024 15:46:56   startup.mdb
      13 drw-           - Jun 26 2024 13:14:49   versionInfo
    If i factory reset will it restore the required files?
