Comware
HPE 5710 switch saved configuration always skipped after boot
  • 1.  HPE 5710 switch saved configuration always skipped after boot
    Posted Feb 05, 2024 12:10 PM
    Hello! I have a HPE 5710 (JL585A)
    I found that it has been unable to load the saved  Configuration file
    as follows
    Starting…
    Press Ctrl+D to access BASIC BOOT MENU...
    Press Ctrl+T to start heavy memory test
    * HPE FF 5710 48SFP+ 6QSFP+ or 2QSFP28 Switch BOOTROM, Version 235 *
    Copyright (c) 2010-2019 Hewlett Packard Enterprise Development LP
    Creation Date: Apr 15 2019,16:05:50
    CPU Clock Speed: 1000MHz
    Memory Size: 4096MB
    Flash Size: 1024MB
    CPLD Version: 002/002
    PCB Version: Ver.A
    Mac Address: EC9B8BCAB0E6
    PEX mode is enabled.
    Press Ctrl+B to access EXTENDED BOOT MENU...0
    Loading the main image files...
    Loading file flash:/5710-cmw710-system-r2702p01.bin.............................
    .....Done.
    Loading file flash:/5710-cmw710-boot-r2702p01.bin.............Done.
    Image file flash:/5710-cmw710-boot-r2702p01.bin is self-decompressing.....
    ................................................................. .........Done.
    System is starting...
    Cryptographic algorithms tests passed.
    Configuration file is skipped.
    Performing automatic configuration... Press CTRL_C or CTRL_D to break.
    Automatic configuration attempt: 1.
    Not ready for automatic configuration: no interface available.
    Waiting for the next...
    Automatic configuration is aborted.
    Line aux0 is available.
    Press ENTER to get started.
    <HPE>show startup
    MainBoard:
      Current startup saved-configuration file: NULL
      Next main startup saved-configuration file: NULL
      Next backup startup saved-configuration file: NULL
    <HPE>save
    The current configuration will be written to the device. Are you sure? [Y/N]:Y
    Please input the file name(*.cfg)[flash:/startup.cfg]
    (To leave the existing filename unchanged, press the enter key):
    flash:/startup.cfg exists, overwrite? [Y/N]:Y
    Validating file. Please wait...
    Saved the current configuration to mainboard device successfully.
    <HPE>show startup
    MainBoard:
    <HPE>
    Password recovery capability is enabled.
        EXTENDED BOOT MENU
    1. Download image to flash
    2. Select image to boot
    3. Display all files in flash
    4. Delete file from flash
    5. Restore to factory default configuration
    6. Enter BootRom upgrade menu
    7. Skip current system configuration
    8. Set switch startup mode
    9. Set default boot storage medium
    0.Reboot
    Ctrl+Z: Access EXTENDED ASSISTANT MENU
    Ctrl+F: Format file system
    Ctrl+P: Change authentication for console login
    Ctrl+Y: Change Work Mode
    Ctrl+R: Download image to SDRAM and run
    Ctrl+C: Display Copyright
    Enter your choice(0-9): 2
    1. Set image file
    2. Set bin file
    3. Set configuration file
    0. Return to boot menu
    Enter your choice(0-3): 3
    File Number File Size(bytes) File Name
    1 8766 flash:/testcfg.cfg
    2(b) 8766 flash:/test.cfg
    3 8424 flash:/starcfg.cfg
    4(*) 8766 flash:/startup.cfg
    Free space: 817242112 bytes
    (*)-with main attribute
    (b)-with backup attribute
    (*b)-with both main and backup attribute
    Please input the file number to change: 4
    But BOOT MENU please tell me is there any way to make it automatically load the configuration after booting into the system??
  • 2.  RE: HPE 5710 switch saved configuration always skipped after boot
    Posted Feb 16, 2024 05:14 AM
    Hi
    The version is way too old (2020-12-14) : current last available version is 5710_7.10.R6710P03 (2023-08-01)
    I shall propose :
    1. upgrade to R6710P03
    2. reset to factory default
    3. display device flash
    4. dir/all (check for free space)
    Then check again and let us know.
    Frederic
