IAP-334s need external antennas and generally you need to connect all 4x of them.
you can go with AP-ANT-1W which is a dual-band Omni-Dir Indoor Antenna (2.4-2.5GHz (4dBi)/4.9-5.875GHz (6dBi) Hi Gain )
Original Message:
Sent: Nov 24, 2022 02:04 AM
Subject: IAP-334 Antenna questions
We have some IAP-334s we need to set up, but I have 2 questions regarding the antennas.
- Does the unit include any kind of internal antenna or are external antenna a must? It's a rather small area that needs to be covered hence the question. I see the purchasing guide does mention antenna, but I'd like to be sure.
- Do you need all 4 external antenna ports connected for it to start transmitting or would 1-3 be sufficient? Same reason as above, small area
There's a bit of a shortage where I am located so I had to make do with what we could purchase
